Old 01-12-2004, 09:57 AM
xunforgivenx86 xunforgivenx86 is offline
do it yourself mods?
any one konw any doit your self moday or sites that have walkthroughs for them....i found one site with a whole bunch of them but im loken for more too.
Old 01-12-2004, 08:27 PM
90Stangjc 90Stangjc is offline
Yeah, go to mustangsunlimited.com and order a catalog. They have a couple little things in the back of their book that would help your car out (i did them to mine). For example... 1.Use a digital volt meter to measure the TPS, it should be between.997-.999, and 1.10-1.25 on supercharged engines. (The TPS is located on the top of the TB). 2. Remove your air silencer. 3. Use a 180 degree thermostat, it will cause your engine to run richer thus producing more power. 4. Remove the insulation under the carpet in the hatch area on hatchback models, its usually about 15 or so pounds. They have some more stuff like bumping your timing up to 19 degrees at max, ect..... good stuff.
1999 Camaro Z28 M6- Aftermarket mods- LS6 Intake, Chip
Home mods - Ram Air mod, !CAGS
FACTORY FREAK BIOTCH!
Old 01-13-2004, 06:45 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: do it yourself mods?
Just a side not, there is no difference in TPS setting between .94-.99 volts. Anything over 1 volts will be bad, and .99 is dangoursly close to the level you don't want to be at.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-13-2004, 08:04 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Also, you can remove rear seats, disconnect PS/AC etc for more power, and remove the sway bar for about 40 lbs.
Mustangs are nice, but I'd rather have one of these...
Old 01-13-2004, 12:50 PM
heres a site i found myself
http://www.mustangworld.com/ourpics/fcar/ctips.htm
i removed my silencer and it worked well and was simple it only took about 10 min......i also lowered my windshield wipers and it looks cool...5 min mod.
Does the ebay resistor mod really work?? hoopdaddy6 Car Rumors & Concepts 1 12-17-2012 06:58 PM
305 mod suggestions gdawgdb Engine and Transmission 2 05-20-2009 03:05 AM
For Sale Great Car mods for basically any car! Jstone616 Cars/Parts for Sale/Exchange 0 05-18-2009 02:25 PM
Do It Yourself Mods integrasedan Integra 0 03-18-2004 09:14 PM
Do these Do it yourself mods actually work? Zwrangler Camaro Discussions 6 01-19-2004 09:26 AM
