Old 01-12-2004, 09:31 AM
Skarytoes Skarytoes is offline
Unhappy Suburban 1999 Window Noise
Hello Everyone,
New Suburban owner here. I have noise problem with my front passenger window. When the window is rolled up tight, I get this creaking sound from the window frame. I have determined that it is the window rubbing somehow. When the window is down there is no noise.
Any suggestions? Can the window be tightened? What do you think is the problem
Thanks
Skarytoes
Old 01-13-2004, 10:12 PM
toivo toivo is offline
Re: Suburban 1999 Window Noise
use a wax or silcone lubricant on you doors weather stripping all the way around the door and see if that helps.
Old 01-15-2004, 04:41 AM
CalessaSSracer CalessaSSracer is offline
wow i just bought my 98 GMC Sub 4x4 last sat night. I also have that noise.
ill try that Toivo
1999 K1500 5.7 Suburban front end noise when turning left Borguy Suburban 1 09-20-2010 09:40 PM
limousime 1.9 TDI 1999 ventilator belt noise kmiki '97+ 0 04-20-2009 02:40 AM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
1999 Suburban rear windows stuck Pat111 Suburban 0 10-14-2006 03:20 AM
1999 K2500 454 4WD Suburban Air Injection Noise On Start Up Ricetuner C/K 0 12-17-2003 07:34 PM
