hornless xj
i hav a 94 xj and MY HORN DOES NOT WORK!!!!!!!!!!!!!! i want to at least find the problem and if possible fix it but i dont know where to start. can i get some help here?
thanx |
check the fuse for the horn under the dash
Re: hornless xj
Already checked the fuses and changed out the bad ones. i dont have a manual with my car so i dont know what fuses are which. it could be that the fuse was not in there to begin with
Re: hornless xj
The manual of my 93 sport says cavity # 11 in the fuse panel is for Headlamp Delay Module and Horns. It's a 25 amp fuse.
The diagram on my box has 8 rows from top to bottom, as follows: On top of box is Combination Buzzer. At upper left beside rows 1 and 2 is Turn Signal Flasher. top row = #1 rear washer/wiper 25A 2nd row = #2 Radio, Radio Clock Illumination, Cigar Lighter, Dome Lamp 3rd row = from left to right #3, #4, #5 #3 is listed as empty empty in table #4 is Flash-to-Pass 15A #5 is Blower Motor 25A 4th row = #6, #7, #8, #9 #6 is power windows 30 A Circuit Breaker #7 is Antilock Brakes 2A #8 is turn signal flasher 20A #9 is Radio, Courtesey Lights, Glove Box, Cargo, Dome Lights 10A 5th row = #10, #11, #12 #10 is shown on drawing, but not listed in table #11 is Headlamp Delay Module and Horns 25A #12 is shown on drawing, but not listed in table 6th row = #13, #14, #15 #13 is Power Door Locks 20A #14 is shown on drawing, but not listed in table #15 is I.P. Lamps, Clock, Radio/Clock Illumination, Rear Lamps, Front Lamps 15A 7th row = #16, #17 #16 is Power Seats, Trailer Tow 30 A Circuit Breaker #17 is Instrument Cluster Guages, Headlamp Delay Module, Chime Module 7.5A 8th (Bottom) row = #18, # 19 #18 is Heated Rear Window 25A #19 is Instrument Panel Lamps At lower left of rows 4,5 & 6 is #20 #20 is Windshield Wiper, Windshield Washer 5.5A Circuit Breaker At lower right is hazzard flasher I hope this helps you. |
If all the fuses are good, use a test light to see if the wire going to the horn actuall has power when you push the button. If no, then check the horn relay (it should have one) and check the horn button the sterring wheel, to make shre it has a good contact.
Re: hornless xj
and how do i find this wire??? i have a test light but have no idea which wire to put it on. if yu could tell me or tell me how to find out i would really appreciate it
I'm taking this from the 1994 Jeep Shop Manual...
The horn should be located on the drivers side under the splash guard. It is mounted with a small bracket held by one bolt. You can try running some jumpers from the battery to the horn to see if it's ok. The horn fuse is the #11 fuse 25 amp located in the interior fuse panel. if the fuse is ok press the horn button, you should hear the horn relay click. If not the horn relay may be bad. It is in the relay center (what jeep calls it). The shop manual says this is located "on the lower instrument panel trim cover just right of the steering column". It has a bunch of relays there (thus the relay center!) that look like little silver boxes. The horn relay is in the cluster of three large relays. It's the smaller of the three closest to the outer panel. If the horn works and you replace the relay and it still does not work then you have a problem either in the wiring itself or the horn switch on the steering wheel. The horn and the relay are the easiest and probably cheapest places to start. :-)
John Harris http://www.electra225.com "Problems are just solutions in work clothes" |
