Old 01-11-2004, 11:17 PM
bigwally9876's Avatar
bigwally9876 bigwally9876 is offline
Send a message via Yahoo to bigwally9876
Angry moves in gear
hello all fellow crx owners, i have an 88 crx si, my crx was down for a bout two weeks cause of a bad CV joint, now that i have changed it my car will roll even when the car is in gear! i have no idea why its doing this my gears have always been fine! some one please help!!!!!!!!!!!
Old 08-19-2004, 01:29 AM
Re: moves in gear
extra.. after we put i the cv joint my friend went to pop the cluth but there was no batt so as it rolled back there was a loud pop and the car could never catch a gear again, i've tighted the linkage cable thats not it so i'm stuck dont know what to do could it be the cluth or the tranny? some one please help.
Old 08-19-2004, 03:06 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: moves in gear
when its running and you put it in gear what does it do? it sounds like you broke an axel
Old 08-19-2004, 08:54 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: moves in gear
sounds like the axle has came out of the gearbox to me , have a look under the car!
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 08-19-2004, 09:24 AM
V-K V-K is offline
Send a message via AIM to V-K
Re: moves in gear
I popped the passenger side axle when I swapped motor because the axle wasn't pushed in all the way. It was a rather loud pop. (was backing car up my steep driveway*
Old 08-19-2004, 05:47 PM
Re: moves in gear
thats how mine happened my friend was backing the car out the drive way(car was off) and then we heard a loud pop, we thought maybe the cv joint so we took it off cause it wasnt fitting perfect exchanged it and the second one went in alot beter but still nothing.**** when the cars running and i put it in gear it just revs but it doesnt even try to move.
Old 08-19-2004, 07:25 PM
Forunn Daberator
Re: moves in gear
yeah its either broke or fell out.
Old 08-19-2004, 09:50 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: moves in gear
Did you replace the correct joint? j/k
There's good advise here, you should be able to find a solution. GL
