Go Back   Automotive Forums Car Chat > Isuzu > General Discussion
Old 01-11-2004, 10:55 PM
barteldt barteldt is offline
Send a message via AIM to barteldt Send a message via Yahoo to barteldt
Question amigo sputters
have a 94 amigo 2.6 l has 193000 miles but runs good . lately im noticing a sputering at low rpms mostly when starting out in 1st and 2nd .seems worse with a load on it like going up a hill.could this be fuek filter or injector problems doesnt seem electrical.wires and plugs are fairly new
Old 01-21-2004, 03:18 AM
grandprixmarine grandprixmarine is offline
Re: amigo sputters
try isuzuauthority.com for technical help they are great....
Old 02-11-2004, 03:23 AM
Re: amigo sputters
no response again
Old 02-26-2004, 08:01 PM
Frozenhonolulu Frozenhonolulu is offline
Re: amigo sputters
I had the same problem with mine and a new distributor cap and rotor did the trick.
Old 02-27-2004, 02:34 AM
Re: amigo sputters
i took off the air cleaner and clened everything up with penetrating oil and sprayed the injectors with carb cleaner seems to be good to go now but still a bear to start im gonna try a cap and rotor anyways so well see what happens
Old 02-27-2004, 12:55 PM
Re: amigo sputters
If you can find an easy way of getting the cap off(aside from removing the engine), let me know. I think it took me about an hour to get it off and put the new one on. Of course it was about 10 below outside. Still, it's in a stupid location.
Old 05-04-2004, 02:30 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Re: amigo sputters
Hey....I have got the same problem wtih my 89 2.6 FI Amigo.....I have replaced cap, rotor, wires...checked all the vaccum hoses....Nothing has worked.... and yes the cap is a bear!!!!!
Next will be the fuel system and EGR valve!!!
If I find it...I will post it....do the same!!!
Old 05-19-2004, 02:33 AM
Re: amigo sputters
put a new battery in it and it starts great. even the check engine went out guess the pump wasnt getting enuf voltage or something like that
