Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 01-11-2004, 09:51 PM
RaulLince RaulLince is offline
upgrading to tach instrument cluster ?
the factory installed instrument cluster with the tach, can it be installed in a truck with a cluster without the tach? Is there expensive hardware to buy to hoow the tach up for it to work i suppose its off the distributor? Not sure at all looking for answers. Thanx Raul
Old 01-12-2004, 09:50 AM
DRAGGNSC DRAGGNSC is offline
Re: upgrading to tach instrument cluster ?
there is only one wire that comes from the distributor....but on the back of the instrument cluster, there is 3 plugs on the back of the clusters with a tach. If you do not have a tach now, then you would not have all of the plugs/harness.
I have a gray tweeded dash with the instrument cluster that has a tach and there is already white face gauges installed for sale if you are interested.
go to my page and check out my truck and let me know.
Old 01-12-2004, 09:54 AM
I also have my wheels and tires for sale...
Old 11-28-2004, 03:57 AM
bigbiz bigbiz is offline
Send a message via Yahoo to bigbiz
Re: Re: upgrading to tach instrument cluster ?
I'm interested in the b2200 speedo w/tach. I couldn't email u so u hit me up if it's still 4 sale.
Old 01-13-2005, 03:55 PM
mazdatech mazdatech is offline
I have ugraded to a tach in my b2200 and i simply plugged it in the wires are already their thease trucks came with a lot of options but some had none
Old 01-13-2005, 05:46 PM
89B2200 89B2200 is offline
Send a message via AIM to 89B2200
It is not really very hard to find out. The tach only needs a 12V power supply and a signal input from the ignition coil.
You can remove your existing instrument real easy and quick and start looking for extra plugs that will match with the new instrument dash. Worst case is you can trace the tach inputs and power leads and just run the new wires.
Old 01-14-2005, 08:27 AM
DRAGGNSC u still tryin' to sell those items? U can't be emailed thru this site!
Old 02-07-2006, 10:13 PM
MAZTANG MAZTANG is offline
its already wired just plug the 3 plugs into the back of the cluster with the tach and it will work iv done it
