Old 01-11-2004, 09:06 PM
joemia2 joemia2 is offline
Angry 04 Silverado engine vibration
Just bought a 04 Silverado 4.3L Ext. cab 2WD just before Christmas. Have been getting a vibration when you slightly apply the gas from the motor, it vibrates through the gas pedal and most of the truck. Had it to the dealer and they said it was normal and they could not do anything about it. They have not had anything go wrong from that vibration. In other words I'm SOL. Can anyone help What should I do? Has anyone out their had the same problem with vibration problem?
Old 01-12-2004, 12:28 AM
phoenixzc phoenixzc is offline
Well you can check out this site and see if there is a bulletin on it. If I where you I would keep bringing it back to the dealer and see the dealer mgr keep going to the top
http://service.gm.com/gmtechlink/ima..._mo/TLcme.html
Old 01-12-2004, 12:31 AM
Re: 04 Silverado engine vibration
try and look at this site.
http://service.gm.com/gmtechlink/ima..._mo/TLcme.html and keep taking it back to the dealer go to the mgr. if he don't care go to the gm mgr if that don't work call gm keep going to the top
sorry for the double post
Old 01-13-2004, 05:18 PM
Thanks for the info. I didn't find anything about any vibrations on the Silverado in the bulletin stuff maybe there will be soon. I will keep taking it back and find someone at the dealer who might want to help or something. Thanks again
Old 01-13-2004, 09:22 PM
99ssconv 99ssconv is offline
should have bought a v-8, they don't have the vibrations like the v-6 does, its normal.
Old 01-22-2004, 11:15 PM
BigblockChevelle BigblockChevelle is offline
Funny I didn't know Chevy Even ofered a 4.3 in the Fullsize truck any more....
Old 01-23-2004, 02:22 PM
CSI-LEVEL3 CSI-LEVEL3 is offline
Your hearing exhaust resonance. It's a problem with stainless steel exhaust systems. Chevrolet is aware of the problem and has a stainless steel flexible exhaust attachment that will fix the problem. This is covered under warranty, and they do have a service bulletin on the problem. It seems to be happening alot with the 4.3, and 4.8 engines. I had the problem with my 2002 silverado ext. cab. They installed the flex exhaust, and the problem is completely gone. Good luck, and ask top see the service buletin, it will explain how the flex exhaust works.
Old 01-24-2004, 10:13 AM
Thumbs up Re: Re: 04 Silverado engine vibration
Thanks so much for the info. Have appointment with dealer thur. will tell them about the fix. Thanks again.
Old 01-24-2004, 10:15 AM
Talking vibration
