Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-24-2001, 01:31 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Just installed 6th gen Si swaybar, on 6th gen DX coupe...
About a week ago, I aquired a stock OEM '00 Si rear swaybar, to put on my '00 DX coupe, not knowing if it would fit or, work right and what-not. During the week, I orderd the mounting brackets to hold the bar to the subframe, and got the bolts to attach it with. Knowing somewhat how the bar goes on, I decided to take today to try to install it myself. Pretty easy actually. I put the rear wheels on some blocks to raise the back end up a bit, so I could crawl in under there, and attached the brackets to the frame, and then attached the endlinks to the lower control arms, and viola! An inexpensive suspension mod. Luckily the LCA's on all Civics (coupes at least) have pre-drilled out holes for the endlink bolts, so doing that part was a piece of cake! The brackets I had to order, ran me about $20 for the pair from my local Honda dealership, and my friend sold me the bar complete with the endlinks for $45. So for a total of $65, it's about the best thing I've done to my suspension setup so far. The entire install only took me about 30 minutes, which was quicker than I thought it would take, but well worth the $30 I saved if I would have had it installed at a shop like I was originally planning on doing. So far, the bar makes the whole rear end feel a bit stiffer, almost as if stiffer springs were on, and even on stock rubber/rims, she corners a bit better, and faster too. Having a rear lower tie bar though, helps out a bit more too, to add to the package.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 12-24-2001, 05:26 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
You are rolling on stock suspension?
If so that is what really helps! Even if you don't that backend is in serious need, for that bar!! Glad you did it, now if you ever go with a race suspension, that bar is the perfect end product not too thick
M.Sanew - AutomotiveArticles.com
Old 12-27-2001, 01:23 AM
Cali Guy
Yup, still rolling on stock springs/struts, but not for too much longer though. It's weird though, people that aren't familiar with the feel of how Hondas ride, always comment to me how nice and stiff the suspension feels. I guess it's pretty stiff in stock form, but I'm pretty used to it, so it doesn't feel as stiff as it could. I dunno... =\
But yeah, I agree about this bar being the perfect size, it's enough to notice and make a difference, yet small enough to not damage anything.
hessemer69 on AIM
