Old 01-11-2004, 12:16 PM
Abbot Abbot is offline
98 Tahoe Fuel Pump Fuse
The fuel pump is not coming on when I turn the ignition key ( no humming sound. ) Its been very cold here the last few days 10 to 20 degrees. Replaced fuel pump relay ....no help...is there a fuel pump fuse
if so where? Or has the pump failed. 97,000 miles. Please help
Old 01-15-2004, 09:08 PM
RacinRex RacinRex is offline
Send a message via AIM to RacinRex Send a message via Yahoo to RacinRex
Re: 98 Tahoe Fuel Pump Fuse
If you have never replaced the pump, you can almost bet that it has failed. I have a 96 Tahoe and it went out once. Then I thought it did again. It didn't help that the parts store was just selling me the pump itself when they were supposed to be selling the casing and all. Also, on the wires to the pump, the ground corroded and was causing a problem. Just some things to look for.
Old 01-20-2004, 02:22 PM
grandlaker grandlaker is offline
Check your manual for information on the fuse. I also have a detailed post on this board aregarding replacement of the fuel pump.
Old 02-01-2004, 09:58 AM
96'tahoe 96'tahoe is offline
no fuse
I have a 96' tahoe and the fuel pump went up on it. I looked for a fuse but found that there wasnt one, atleast i was unable to find one. when i replace the pump i made sure the ground wire was clean and put a little electrically conducting grease on it before i put it back together. seems to work good now (a year later) but now it is humming up a storm.... damn i hope it doesnt go again....
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 11:42 AM
2000 Tahoe LT Fuel Pump, Cats and Door Actuator ediesel_b13 Tahoe 0 05-14-2010 11:36 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-05-2009 12:39 AM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 10:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 09:04 AM
