Old 01-11-2004, 08:16 AM
muttd4h muttd4h is offline
Engine won't start, all other electrical fine
I have a 2001 Tahoe LS. Got up to start her and...nothing. All electrical seems fine. Radio, power seats/locks/windows. Even the headlights and fans work. I checked all the fuses in both the passenger and engine compartments that relate to ignition/starter/crank. They are all good. On the fuse boxes there are these big grey blocks that I assume are some type of relay. Can those be pulled out and checked? Was afraid to try.
From the above I assume the battery is not the problem so I did not jump it. Does anyone have a suggestion on what to try next? I really thought the fuse would be the problem. Thank you for any help you can provide.
Rick Herrick
Old 01-12-2004, 12:06 AM
BadBoy1404's Avatar
BadBoy1404 BadBoy1404 is offline
Send a message via AIM to BadBoy1404
Re: Engine won't start, all other electrical fine
Hey man my 03 tahoe just was doin the same thing its goin to the dealership tomorrow i will let you know what they say.
2000 Black Silverado Standard Cab Stepside
K&N, Flowmaster, exterior paint touches, sound system
View My truck more in depth
Old 05-06-2004, 04:12 PM
Tahoe4me Tahoe4me is offline
Re: Re: Engine won't start, all other electrical fine
My 03 is also doing that. Did you ever find the problem?
Old 05-06-2004, 04:17 PM
Re: Re: Re: Engine won't start, all other electrical fine
In my case it was the alternator. $450...
Mutt
Old 05-09-2004, 07:51 AM
RW5207 RW5207 is offline
I have a 2003 tahoe that had the problem. Fuel pump was the problem. About 41,000 miles. Luckily, I had an intermittent start problem that GM was aware of while under warranty and they replaced the fuel pump. Would have been over $700.
Old 06-05-2004, 11:46 PM
ditto03 ditto03 is offline
I have a 2003 Tahoe Z71 that has a problem. Something is draining the battery. I replaced it and now the second one has died. Dealer had no idea. Said it was a bad bolt connecter!!! Any idea what could be the cause of my problems?
97 chevy cavalier won't start changed plugs ran fine two days ladagosta Cavalier Problem Diagnosis 17 07-12-2011 12:26 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
Reverse wont engange, all other gears fine. georgelovesdirt Problem Diagnosis 3 06-11-2007 11:15 PM
No Start - All other electrical OK todd.gundlach Trans Sport 3 04-15-2007 08:39 PM
94 Jimmy-Won't start, everything else is fine! SammyJo13 Jimmy 2 02-23-2006 08:15 AM
