Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-11-2004, 05:04 AM
colbydmay colbydmay is offline
Seals on '90 V6 Camry: how many, how much $$, how hard to replace
The wife's Camry has begun to leak oil at a pretty good clip. Noticed the other day some smoke coming off the engine, so I poked around a little bit. Looks like there's several oily places on the engine, so I'm thinking some seals/gaskets are going bad (probably have never been replaced...car has 115K miles on it). Anybody with a '90 (or similar) V6 Camry know how much this might set me back? And should I go ahead and get the timing belt done at the same time?
Thanks for your thoughts, all.
Old 01-12-2004, 01:57 PM
Enigmaglc Enigmaglc is offline
Send a message via Yahoo to Enigmaglc
Re: Seals on '90 V6 Camry: how many, how much $$, how hard to replace
I had a similar problem before. Sounds like a head gasket. DYI is tough but if you have the tools and time its ok. Dealers charge approx 300.00 depending on labor. A local garage can do it for a little less. Get the timing belt changed to!!!! Already way past its time
Old 01-13-2004, 07:56 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
I'd say head gasket, but it could also be a valve cover gasket as well. I know that you will save yourself an assload on doing it yourself, but if you don't have the tools, you'll be paying just about as much for the tools to do it as you would just taking it somewhere and having it done. Valve cover gaskets are relatively easy to replace, only requires a ratchet and socket, although the head gasket is a little more difficult.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 01-14-2004, 08:35 PM
corvair corvair is offline
i'm sure you will need a rear valvecover gasket and the intake plenum will have to be removed to get to it. good time to change those plugs too
have the engine cleaned then check, if one gasket or seal is bad the others arn't far behind.
