Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 01-11-2004, 12:05 AM
sharrk27 sharrk27 is offline
jetta backfires under load
95 2.0 jetta stick,just had tune-up plugs cap rotor fuel filer injector cleaner ,runs fine at idle wont pull over 3000 under load without backfiring,was run low on gas just before fuel filter was changed,everything looks ok plugs read nice all cyls burning cleancar ran good just started this ,driving down the road anybody have any ideas,thanks
Old 01-12-2004, 08:29 PM
boschmann boschmann is offline
Re: jetta backfires under load
Check the engine codes. If it started after the tune-up parts, check them first. Plug type & gap, cap & rotor quality/properly seated, wire condition/resistance.... It also could be the coil starting to break down.
Old 01-13-2004, 09:51 PM
Re: Re: jetta backfires under load
thanks for the help bob
Old 01-30-2004, 07:41 PM
mmichalak mmichalak is offline
sounds to me like you may have an ignition timing problem, maybe a mistake was made when installing the rotor along with the cap and plugs, retarted ignition timing can often lead to backfiring and power loss depending on how severely retarted it is, or if there is no power loss could be too advanced, especially if u dont have a knock sensor to retard the timing once it starts knocking under load..........
