Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 12-23-2001, 09:14 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
What mods have you done to your CRX?
I've had my CRX for almost a week now, and I've decided it's about time to increase the HP. I already have I/H/E installed, but I was wondering what my fellow CRX owners have done to their ride to pull out a few more ponies.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 12-24-2001, 12:06 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Thumbs up Mods
Well i would suggest doing something like AEM pulleys or even a AEM camsprocket. The pulleys can add about 8hp and it's about the same for the camsprocket. The pulleys run about $100 and the camsprocket runs about $150. I guess that's something you can do for a few more ponies.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 12-24-2001, 08:19 AM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
Question
I wanted to put on a pulley kit on my engine, but a friend told me to not to do it cause the alternator would die down when the car came to a stop. Have you heard anything about that?
R.I.P. - You shall be resurrected.
Old 12-24-2001, 10:12 AM
91b16sedan 91b16sedan is offline
I know the pulleys can drain the battery. they also can be hard on the motor. If you wnat to get some more power out of your motor you should get web cam for it.
B16a
Other Mods
14.8 @ 94 mph
Old 12-24-2001, 12:47 PM
90CRXZCSi's Avatar
Question pulleys
No, i've never heard of it dying at a stop. The only way it gives more power is because the pulley is lighter than stock and it spins faster, in turn giving your alternator, water pump and everything MORE power. I dunno what to say.....
Old 12-24-2001, 04:23 PM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
Hmmm... if the pulley is the same diameter as stock I don't see how it would spin any faster, just spin with less resistance to the motor. If it's an underdrive pulley (smaller than stock) it'll make more power but cause your water pump, alternator, etc to spin at slightly lower RPMs. I've never heard of any damage caused by underdrive pulleys.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 12-24-2001, 11:01 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
i have an underdrive pulley on my si, it does slow the alt. and what not down, but not to the point of it killing over, but my lights def. dim, don't do this if you plan on a system of lots o neon and what not, i also have msd, didn't give me any power but it surely runs better and smoother
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 12-24-2001, 11:08 PM
Marc-OS's Avatar
Ok, I'm runnin' 2 12" subs pullin' 400w each, would I need a more powerful alternator if I were to install an underdrive pully?
20 GOTO 10
RUN
Old 12-24-2001, 11:48 PM
if you've got a sound system pulling any sort of power you don't want to underdrive your alternator, underdriving is like replacing your alternator with a little baby alternator so why would you do that if you've got a system?
1991 CRX SI (black)
'90 B18A1 swap
Custom exhaust
*2.25" piping
'95 GSR 15" wheels
Powerslot rotors
Metal Master pads
Skunk2 shift knob
