Old 01-10-2004, 09:34 PM
sbddude sbddude is offline
AF Premium User
HELP! Major Electrical problems
My car was stolen and the stereo, rear speakers, seats and battery was stolen. I think they did some electrical damage when they took the car and i am trying to fix it. Any help is really appreciated.
I have a 1991 Prelude and the more i try to fix it the more I find is wrong with it. The brand new (pioneer) radio I installed does not turn on. There is 12V measured at the BATT lead and 12V measured at the ACC lead when the ignition is on. The ground measures very small resistance between stereo ground and cigarette lighter ground. When i plug in the stereo to the harness, I hear a click in the trunk and the radiator fan turns on. When the stereo is disconnected, ignition off, and i press the cover of the clock (supposed to turn clock on while held down), radiator fan comes on, click in trunk. The cigarette lighter works.
When the car sits for a few days, the battery goes dead. The battery is brand new. The car starts fine when starting only after a day.
I think that's all the symptoms and observations. If you know about this kind of stuff, please take a minute and post a reply. I really appreciate any help.
Old 01-11-2004, 12:06 AM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
as you prolly already have check all fuses and try regrounding the head unit it may be tryin to pull ground.
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 01-11-2004, 12:55 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: HELP! Major Electrical problems
I know you are a bit ticked about this, but try to limit it to one forum that you post this in, so far I have found three on this Bulletin Board.
www.cloudcity.deviantart.com
