Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-10-2004, 06:28 PM
dropped93gsr dropped93gsr is offline
fuel pump/swap problem
ok i have a 93 integra gsr chassis with a 90 ls motor converted to obd 1 runinng a pr4 manual ecu, imusing the automatic wiring harness, however leaving the auto connectors alone,iwas told this works as long as ihave a manual ecu, BUT heres the problem, after the swap, when i turn my key, the fuel pump doesnt work, the fuel relay was tested, and works, when we bypass the relay, the pump works, could my ecu be bad ? i need to get this running thanks!
Old 01-10-2004, 10:52 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: fuel pump/swap problem
pr4 is OBDO not obdII the P75 is OBDII. Why don't you use a manual harness? I am sure that would fix the problem.
Old 01-11-2004, 11:35 PM
no pr4 is obd o and 1, and i dont need obd2, however, the harness we used works fine, and i know someone who used it and had no problems, so its not that
1991 Regal Custom- Possible Fuel Pump Problem snickerkisses Regal 1 02-10-2010 10:08 PM
GTP fuel pump resistor problem... gtp4life Grand Prix 12 01-24-2010 09:32 AM
93 suburban fuel pump problem. robert1984 Suburban 2 12-15-2009 02:21 PM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
