Old 01-10-2004, 06:19 PM
Magik Si's Avatar
Magik Si Magik Si is offline
Air Intake Question??? Squeal?
I just put an air intake on my car (d15b1) and it was off an integra or something...I got it for $30...it wouldn't fit around my battery so what I did was cut the tube and took out the stock filter box etc., and put this in there using the stock tube into the manifold. So now the "cone" is sitting where the stock filter box was. It works fine...the problem is every time I step on the gas to 'go'...I am getting this "squeal"...what did I do wrong?? What's the problem?
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 01-11-2004, 10:54 AM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
it could be just ur alternator belt loose.. Is it a squeal or a loud high pitched sucking noise?
Old 01-11-2004, 12:10 PM
Magik Si's Avatar
It's not the altenator belt because I was out driving around 5 min before I put it on...
Jason
Old 01-11-2004, 02:50 PM
vesper's Avatar
vesper vesper is offline
Send a message via AIM to vesper
Re: Air Intake Question??? Squeal?
its the filter its makes that nosie on a after market intake
Old 01-11-2004, 03:03 PM
91civicDXdude's Avatar
what you're actually hearing is the EACV. on the stock intake, you cant hear the EACV motor turning because the airbox quiets it down too much, but once you put a free flowing filter and bigger pipe on it, you can hear it opening and closing.
I'll bet it only does it at certain rpms, and in some cases, it sounds kind of like a turbo spooling
Old 01-11-2004, 08:59 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
mine sounds awesome, it does sound like a turbo spooling once and awhile, when its fairly cold u can really hear it
Old 01-12-2004, 02:06 AM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
yea intakes arnt stock so naturally something is gonna not work exactly right. I just test drove a 98 civic with an aem intake and i heard this little whine when i reved it up. at first i was like wtf, then GTA asked me about it before i could get a chance to mention it and pointed out that it was the intake at work.
kinda weird if you ask me but hey ... lets you know your really getting more air in there huh?
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 01-12-2004, 08:38 AM
Magik Si's Avatar
Very weird...sounds like your tuning a radio and your getting that "whine" that you get when you're not quite getting reception...very strange that like 91civicDXdude said that it only happens at certain rpms and such...I have to check that I have no leaks...perhaps it is just some air escaping where it shouldn't be that is creating a 'whistle/squeal'??
Jason
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 03:48 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 06:11 PM
Important Cold Air Intake Question Accord4u2nv Accord/TSX/Accord Hybrid 5 02-06-2002 01:47 PM
Air Intake Question.... kicker1_solo Engineering/ Technical 14 01-09-2002 02:39 PM
air intake question SkylinesKillAll Engine 18 04-27-2001 08:51 AM
