Old 01-10-2004, 08:53 AM
Bhall Bhall is offline
Amp fuse
I bought a precision power amp istallation kit and with it came a fuse. It bolts into the floor and has two connectors on either end for a wire. which wires do i hook up to it?
Old 01-10-2004, 12:04 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Amp fuse
It goes in the power wire coming from the battery, you want the fuse within 18 inches of the battery and you can mount it in the engine bay wherever it will fit.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 01-12-2004, 06:53 PM
Re: Amp fuse
Why does the fuse have to be 18 inches from the battery??
Old 01-12-2004, 08:06 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Amp fuse
This way when the fuse blows it doesn't screw up your entire electircal system. I forgot the exacts though...
www.cloudcity.deviantart.com
Old 01-12-2004, 09:26 PM
sr20de4evr's Avatar
Re: Amp fuse
It doesn't have to be exactly 18 inches, you just want it to be close and that's as far away from the battery as you should put it. The fuse is there to protect your car, if your power wire were to ground out to the chassis and you didn't have a fuse, a shitload of current would flow through it and could quite possibly light the wire and then the car on fire. If you have a fuse then it blows and nothing bad happens. The closer the fuse is to the battery, the lower the risk of a groundout causing a fire.
'01 Black Sentra SE
'05 Silver WRX STi
Old 01-13-2004, 06:05 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the 18" is just a convention .... when they started doing car stereo competitions, they had to have some finite number - so they picked 18. That ahould place it in the engine bay, fairly close to the battery and still allow for some flexibility - especially in the custom installs.
Old 01-14-2004, 05:50 PM
Re: Amp fuse
okay, i've got my amp all hooked up with the fuse in the engine bay. when i turn it on theres a high pitched whistle that gets louder when i rev the engine. any clue what this is???
Old 01-14-2004, 10:43 PM
sr20de4evr's Avatar
Re: Amp fuse
alternator whine, normally caused by a bad ground or your rcas being too close to your power wire
'01 Black Sentra SE
'05 Silver WRX STi
Old 01-17-2004, 06:18 PM
Audio Guy
Re: Re: Amp fuse
it keeps going ... and going ........ and going .......
Old 01-18-2004, 03:22 PM
sr20de4evr's Avatar
Re: Re: Re: Amp fuse
what does?
'01 Black Sentra SE
'05 Silver WRX STi
Old 01-18-2004, 04:02 PM
Haibane's Avatar
Re: Re: Re: Re: Amp fuse
what does?
The Energizer bunny
Old 01-22-2004, 05:53 PM
Audio Guy
the RCA cables too close to the power wire thing .... if you REALLY look at it, you will see how silly that assumption is.
The volume of the aternator whine stays constant, even when the stereo is at minimum volume. When the stereo is at minimum volume, there is practically no current flowing through the power wire to the amps - if you're theory were correct, the volume of the whine would be dependent on the power coming though the power wire (relative volume of the stereo).
Old 01-22-2004, 06:33 PM
sr20de4evr's Avatar
Re: Amp fuse
you do have a point, but amazingly it can still cause noise if you have crappy rcas. Either way, it's good practice to separate them, even if the chance of it causing a problem is 1/10.
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-02-2004, 11:49 AM
Re: Amp fuse
it must be a bad ground then because i have my RCA's and my power wire on different sides of my car.
Old 02-03-2004, 06:31 PM
Audio Guy
try using UTP (unsheilded Twisted Pair) RCA's .... the coax cables tend to be noise antennas
