Old 01-10-2004, 07:12 AM
rickr125 rickr125 is offline
1995 Mustang AC/Heat /Defroster
I summon the mustang gods once more. My heat,AC, defroster switch was working fine until yesterday. Now, no matter what switch position, it stays vented to the defroster. Whether I switch to Ac, floor, panel, mix, etc...nothing happens. Anyone ahev experience on ehre to look? I appreciate it. Thanks.
Old 01-10-2004, 04:52 PM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: 1995 Mustang AC/Heat /Defroster
switch is broken, or vent is stuck
Mustangs are nice, but I'd rather have one of these...
Old 01-10-2004, 05:41 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
did u mess with any vacuum lines lately. if not your heater linkage might be stuck or have come off behind the knob.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 01-10-2004, 06:09 PM
Hadn't touched anything but is that switch electrical? It works in the off position but every other position, blower works ok but stuck in defroster to the windshield. Is it easy to get to the door that is supposed to move?
Old 01-10-2004, 07:58 PM
even in newer mustangs, they still use some linkage setups in the heater boxes. you should probably have a shop check it out then, unless you wanna check under the dash and try to fiddle with it yourself.
Old 01-10-2004, 08:18 PM
sheri sheri is offline
Does anyone know where I can find a picture of a hand drawn 65-69 mustang????
Old 06-03-2004, 09:14 PM
fakesnake357 fakesnake357 is offline
i sent you a pm, but i do not know if you got it. so i will reply here. i had the same problem with my 95 mustang, and i would like to share some info with you. if you lift up your hood and go to the driver's side. you will see a black cylinder shaped unit with several black plastic lines coming out of it. check to make sure all lines are okay. one of mine broke somehow and caused the same problems you are having. to fix it, i pulled the broken piece out of the rubber gasket and re-inserted the good end with a little superglue and it works perfectly again. hope this helps.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
