Old 01-10-2004, 02:35 AM
skylovia skylovia is offline
sound when i accelerate
hey guys(and gals, lol). I just discovered this site and thought you guys could give me some help. I have a 1995 mustang GT(automatic). I just got it like 2 months ago and i currently has 73,000 miles on it. the problem i am having is that when i am accelerating from a standstill i hear this loud click coming from under the car. i am not sure where it is coming from since i cant really tell when i am in the car. this doesnt happen all the time but it really worries me when i do hear it. any help you guys can give me would be much appreciated. Thanks!
Old 01-10-2004, 03:41 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
We would love to help, but the discription you gave is not detailed enough?
You might just want to take it to a garage, and see what they say. Then get back to us. Make sure they are not blowin smoke
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 01-10-2004, 07:06 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: sound when i accelerate
Welcome aboard!
So yeah, more info would be good. First find out if its RPM specific, or MPH specific. Does it do it in neutral or while driving. When it happens, remember what you were doing when it happened, then try and replicate it to pine point when it happens. Other then that, there's not too much else we can do over the Internet. Noises are very hard to diagnose without hearing, ya know?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-10-2004, 12:58 PM
Rodek Rodek is offline
hey skylovia -
i might be having the same problem, check out my thread called "grinding gears" ..it still should be in like the top 20 threads or whatever...mine happens at around 1k rpm or so. Mine is more of a somewhat gridning noise as opposed to a clicking sound. If that is similar let me know. I was recommended to change my transmision and differential fluid.
Old 01-11-2004, 02:28 PM
so here is exactly what happens and what i do. i will be at a complete stop, foot on brake. ill release the brake and push in on the gas. the very moment my foot makes contact with the gas pedal, i will hear the sound, like a loud "clunk." like if something was hitting something, ill only hear the sound the very moment i touch on the gas wont hear it again until i come to another stop and touch the gas again. i am always in drive when i hear the sound. i hope this helps more.
Old 01-11-2004, 07:13 PM
HiFlow5 0's Avatar
Stanger
Shift from drive to reverse will sitting still, don't give any gas though. Listen to see if you hear the clunking again. It's possiable that it could be u-joints.
-2013 Ford Flex
-1999 Ford F150
Old 01-11-2004, 07:15 PM
okay, that definently sounds different than what happens to me. I have a 5spd, so that is maybe why my deal is different. What I was recommanded to do was have my manual transmission and differential fluid drained and replaced.
Old 01-11-2004, 07:35 PM
oldsaltdoggie's Avatar
oldsaltdoggie oldsaltdoggie is offline
Send a message via AIM to oldsaltdoggie
I heard a noise like that in my daughters car the other day! The past owner had put window weights in the trunk I did have a noise problem with my 94 Mustang I found that under hard accelaration* the drive shaft was rubbing on one the E- brake cable!
Old 01-12-2004, 01:16 PM
i am taking mine to a Jiffy Lube to get my manual transmission and differential fluid replaced..i will let you know if that does it for me
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
sounds like u-joints to me too...
might also be a tranny mount...
My Project Write-Up
Old 01-14-2004, 11:38 PM
burly94gt burly94gt is offline
hey, i know that the 94 and 95 gt's have a really bad prob. w/ detonation when excellerating to high rpms...if its a pinging sound thats prob the deal... it can be fixed by bumping up the timing a bit
Old 01-14-2004, 11:50 PM
SkylineUSA's Avatar
You retard, not advance with detonation.
Old 01-15-2004, 12:13 AM
HiFlow5 0's Avatar
Stanger
LOL, yeah advancing the timing on a car that's got problems with detonation will make it worse.
-2013 Ford Flex
-1999 Ford F150
Old 01-15-2004, 12:50 AM
okay, well I can't confirm this, but i had the tranmission and differential fluid replaced, and my dad is reporting that the grinding noise i reported earlier has stoped. I won't be 100% sure until I go home this weekend to test this out myself, but things are looking up. I believe that is the last of my problems with the car and I finally get to take it back with me.
I will try to get pictures up as soon as i get a hold of a digital camera...don't know if anyone is interested..but who cares, i can post what i want
Old 01-17-2004, 08:10 PM
okay, i guess all is not well in paradise...the grinding seems to have been reduced significantly....from where i heard it in almost every time i went into first, to now much much more seldomly....but alas, it is still there..so i am stumped
