Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 01-09-2004, 11:08 PM
rshelby2001us rshelby2001us is offline
Send a message via Yahoo to rshelby2001us
83 733i power steering
My power steering pump is making noise like it needs to be filled. How do I do that? This is my first bmw and I don't see where to fill it.
Old 01-10-2004, 02:48 AM
KC Ron Carter KC Ron Carter is offline
Hmm,
There is a reservour for the steering and power brake booster.
It is a round metal cylinder with a metalcap with a center screw lock.
Fluid is Power steering fluid or ATF, which ever you have.
There is a filter in the bottom of the reservoir if it does not need service.
This filter can cause fluid starvation.
If still making noise after the service and or filter you need a pump change.
Not to bad.
Here is a link to the e24 site with lots of help.
http://normgrills.net/bcg/
Later,
Old 01-10-2004, 09:41 PM
Re: 83 733i power steering
Thank you sir !!!! Much obliged...
Old 01-15-2004, 01:13 PM
jeff '84 733i jeff '84 733i is offline
Send a message via ICQ to jeff '84 733i
Do NOT use Power Steering fluid in the hydro booster!
The power steering fluid will cause the gasket to expand and deteriorate and the system to leak. It will also cause the power steering pump to go bad. Use ONLY ATF in the hydro booster. Here's how to do it.
Before you start the car in the morning, or after it has not been run for a couple of hours, open the hydro booster and check the level of ATF in there. Get in the car and without starting the engine, pump the brake pedal 15 times. Then check the level of the ATF in the booster. If the level has not risen to 1/2 inch below the top, add more ATF until the level is there.
There is also a filter at the bottom of the hydro booster that has a tendency to smoosh after a while because of all the pressure in the hydro booster. Replacement of that part will help. Just beware as there is a spring with other parts on it that will shoot out of that thing and you will have a hard time finding the parts and then figuring out which order they go back together.
Let us know how it goes.
