Old 01-09-2004, 10:40 PM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
oil on spark plugs
when i was changing my spark plugs one of them had a lot of oil on them. what does that mean and is it hard to fix?
Old 01-09-2004, 11:38 PM
tibby01 tibby01 is offline
hopefully, it either got on it whben you took it out, or its not oil. if it is oil, it means one of many bad things:
worn pistons allowing oil past the rings(unlikely)
bad seal somewhere in the head.
Old 01-10-2004, 01:36 AM
BullShifter's Avatar
Re: oil on spark plugs
Where was the oil? Top or bottom? If bottom, what tibby01 posted. If top, spark plug grommets and/or tube seals need to be replaced. Grommets are simple, tube seals are a bit more involved(required removing the rocker assy./valve adjustment)
Old 01-10-2004, 01:56 AM
the oil was all over the tip and threads of the plug.
Old 01-10-2004, 01:59 AM
Time for an engine swap or rebuild.
Old 01-10-2004, 02:54 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
All over the tip of the electrode end or the top end that the plug wire attaches to?
Old 01-10-2004, 05:54 PM
electrode end
Old 01-10-2004, 10:23 PM
whtteg's Avatar
Yep what they said new motor or rebiuld soon. Sorry man.
Having 3.5L spark plugs in a 2.7L engine. Benjamin_2002 Intrepid 1 02-28-2011 05:19 PM
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 08:19 PM
spark plug analysis keilerstag Cutlass Series 1 06-29-2009 08:25 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
