| Off-Topic Talk about anything other than cars. |
Evo Viii
Is it true that the evo viii has the 4g63 motor? Sounds like a dumb question but i dont know much about evos
yup
- Its Micheal Jackson! and his black again!!! YAY!!!!!!LandoAWD - My rolemodel!! why? because his a bad ass! beache..! and he will kick ur A$$!! ![]() Originally Posted by Delerious93integra and if DSM's are so great.. then why doesn't everyone own one? ^^^ WOW!!! ^^^
Re: Evo Viii
So what mods would be needed to make the gsx/gst have the same or more hp then the evo? 16g and a fuel pump? or is ther any other stuff
Re: Evo Viii
upgrade the turbo fuel pump probably new injectors. I would get a greddy boost controller then i think you would be good. Don't run too much boost but you can get 300 hp out of that engine pretty easily
Re: Re: Evo Viii
yup same engine... stock FMIC too... and EVO 16g turbo... supporting mods...
Re: what mods would be needed to make the gsx/gst have the same hp as the EVO VIII?
If your car was stock, I would start off by upgrading your air intake, a K&N air filter, and replace the restrictive UPIC pipes. Also, do the MBC at this time. I would next do a fuel pump, downpipe and exhaust. No sense in having a turbo if you are going to choke it. Now when this is complete go with injectors and a turbo. ONLY do the turbo when you have the fuel and air flow to back it. Oh yeah, when you get injectors you should also get a controller like S-AFC. Don't know what year the car is, but if its a 2g you would need a 1g bov or something and should be replaced when the UPIC pipes are. Also a datalogger, very important.
I'm not sure I understand the question. You can almost match the power of the EVO with the stock 2g turbo. 1g is no problem. Very minor mods will be required to match the power of the evo, and you can build 3 equal 2Gs or 4-5 1Gs for the cost of a new EVO
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
the Evo doesn't have alot more power then the Eclipse so it should be quite easy to match its power as 95gsxracer said. try an Evo III Big 16g Turbo [stock turbo from Evo] Evo III Manifold, Evo III 02sensor, and a few other minor mods and u should get more then enough power then an EVO.
"Cant you see that your smothering me, holding too tightly, afraid to loose control cause everything that you thought i would be, is falling apart..right in front of you....every step that i take is another mistake to you, and every second i waste is more then i can take" |
How much just for the parts would i be looking at the get the car to 300hp give or take? K&N and a exhaust is a must but besides those how much whould the EVO 16g and the other parts all of you guys suggested cost?
Evo 16g $569
Fuel Pump $90 Injectors $270 Turbo install only on a 2g $200 Downpipe $240 These are all rough estimats on prices, which may very due to supplier. I don't think you said weather you had a 1g or 2g. If you have a 1g, you wouldn't need a new turbo the 14b is well capable of producing 300hp. |
Re: Re: Evo Viii
I would want to know how I could I have at least the double horsepower of GSX. Stock it runs 210 I think So how would I be able to get to like 400 horsepower.
Horsepower of an Evo isn't hard to get to.
Now, that beautiful drivetrain and chassis.. that's a diff. story. |
So how u think I can get 400 hp out of my GSX???
by doing alot of research
DSM geek |
oh yea, 400HP is very possible for a DSM of any type. However, I would suggest you set your mind on short term goals for now. A 60 trim should get you up to 400HP or so, but that will require A LOT of supporting mods. If you are going for around 300-350....i would go the route I am on.
FIPK (K&N $100) Hard Intake Pipe ($80 used) UICP for 1G BOV (Dave Brode $65) 1G BOV ($30 used) Manual Boost Controller ($40) Gauges (boost & EGT - $210 or so) 3'' cat-back ($300-500) 3'' DP w/ HFC ($350) 190lph Fuel Pump ($100) Evo III 16G ported with 35 MM FLAPPER A MUST! ($650-$700) 2G Install Kit ($200) 1G intake manifold and TB ($100 used) Then SAFCII and datalogger, a bigger fuel pump, and EBC and and im pretty much good to go. Then just tuning it to a good DD setting, and im good to go for well over 300 very safely. |
