Old 01-09-2004, 05:41 PM
Kinked210's Avatar
Kinked210 Kinked210 is offline
Send a message via MSN to Kinked210
Question Electric Superchargers?
I was browsing turbo/superchargers on ebay when I came across an electric supercharger for like $100.
It says they aren't car-specific..like one fits all Hondas.
It's supposed to add like 70HP. It's like a 6" x 6" fan basically that hooks onto your intake. It says you need a 3" intake for it to fit.
I was just wondering if it really helps that much...for that cheap!
Old 01-09-2004, 05:52 PM
Dynwolf Dynwolf is offline
Send a message via AIM to Dynwolf Send a message via Yahoo to Dynwolf
I can't believe that it would work - could you send a link?
I work for an aerospace company and, among other things, we design and manufacture high-performance turbomachinery here (read: high pressure and/or high flow aerospace grade fans). From what I understand, turbos can generate from 8-12 psi of boost, though I don't know how MUCH air (in cfm) they generate. I'd need both sides of the equation to fully calculate, but at 8-12 psi, you're effectively talking about a low volume compressor.
We've got a unit that generates about 2 psi at 90cfm, works at 28 volts and draws far more amps than the average component in your car. Based on this, I can't see how an "electric blower", as it were, is feasible.
JM
EDIT : 1/12/04 for clarification in 3rd paragraph.
Old 01-09-2004, 05:58 PM
Kinked210's Avatar
It pulls from your battery at I think it said 3psi. 12 volts.
Here's a picture of it...I'll get back to you on the link in a minute...
Edit: cant upload it lol...how do you upload pictures?
Old 01-09-2004, 06:00 PM
Kinked210's Avatar
Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452200213
Old 01-09-2004, 10:21 PM
mattyoung33 mattyoung33 is offline
Send a message via AIM to mattyoung33
Bullshit You Noobs
'99 Honda Civic HX
-17" ASA rims with Khumo's
-Lowered about 2" w/ eibach sportline springs
-KYB AGX full-adjustable gas shocks
-Injen cold-air intake
-Thermal full-catback exhaust
-Mugen style front/rear lips, type-zero sideskirts
-Grillcraft upper black grill
-custom painted interior
-strut bar
-hyper white headlight bulbs/piaa signals
-new paint job including painted side trim
Old 01-09-2004, 10:34 PM
CivicEXRider's Avatar
CivicEXRider CivicEXRider is offline
It's junk. At 6k rpm on a D16Y8 it needs atleast 400CFM of air to run. That thing would only be hindering air flow.
Wonder how much power it would take to push 8psi at 400cfm?
Old 01-09-2004, 11:36 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
Re: Electric Superchargers?
thats a nice A/C blower fan they are selling there... lol
LS1 RX-7 Zoom Zoom
Old 01-10-2004, 12:34 AM
96Civ's Avatar
96Civ 96Civ is offline
Sounds like one of the most stupid scams out there.
Old 01-10-2004, 01:05 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Re: Electric Superchargers?
one of the oldest too. I believe at www.homemadeturbo.com they actually made their own little electric supercharger kit and tested it out. They ended up taking the baseball bat to it or running it over or something like that
Empty Pockets Racing Member #1
Old 01-12-2004, 07:17 PM
Originally Posted by mattyoung33
Bullshit You Noobs
What a thouroughly insightful and articulate response. So nice of you to draw from your wealth of experience to answer Kinked210's question. Further, had you actually taken the time to read my answer, you would have understood that I was basically saying the electric turbo was unlikely to be of any help.
Give me a day or so and I'll see if I can calculate that out.
JM
Old 01-12-2004, 07:33 PM
BlueBurr BlueBurr is offline
Send a message via AIM to BlueBurr
I had an idea like this awhile back,take a really high powered leaf blower ,most put about 400 cfm,and get a very very powerful power inverter probably 3000 watt,then if you wanted to get really technical about shit you could install a volume control knob in place of the switch on the leaf blower and hook it up to your throttle body so as it turned it would turn the dial on the leaf blower allowing it to spin faster.I failed to realize that you also need fuel upgrades for this to work just as a turbo system.This way would be better for turbo charging cause it would save room and weight(no FMIC,extra piping,blowoff valve,wastegate,or a turbo manifold) which is alot of weight and room if u think about it.So far as trying this idea ive done ,especially after i installed my fuel management unit with a 12:1 ratio I couldnt do a full test on it because i had to turn on the leafblower first then run back to my car and turn it on.I intentionally wanted to run my car with the ebrake up and floor it then have someone plug it in and see if i got any tire spin.Ill let you know tommorow if it works or not cause im doing the full test.
Old 01-12-2004, 07:38 PM
96Civ's Avatar
I have always had the idea that you could end up combining a turbocharger WITH an electric leafblower. It could feed the turbo air, maybe decrease lag, and increase power! Just my dream. It would be one hell of a circus under the hood. Vooooooo-VVvvvvoooooOSSSHHH.
Kinked210's Avatar
wow..that would be something...if it works..ill be the first to buy ur new leaf charger!
1996 Honda Civic Ex
D16Y8[SOHC VTEC]; 5-spd
AEM Short Ram Intake
DC Sports 4:2:1 Header
Tsudo N-1 Midpipe
Old 01-12-2004, 10:49 PM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
www.boosthead.com
Its the Thomas Knight ECS-400
20psi in 3/10 of a second
You'll never see it in any of my cars though.
Old 01-12-2004, 11:57 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Originally Posted by spooleffect
www.boosthead.com
That would be interesting in a strip only application. Since it only works for 15 seconds at a time. I still would rather go with turbo. Thats kind of funny that they claim a motor with 130hp will generate 230hp with the ESC, 203 with a regular SC, and 216hp with a turbo all at 7psi. Thats with header/manifold and CAI even on the turbo some how in the application. Without CAI on the turbo it's 207hp.
Check out my car here My 91 Hatch
Electric Supercharger!!!!!!omg... dangerranger02 Ranger | Courier 49 02-21-2013 10:56 AM
Electric Supercharger - Interest Poll mwillmon Integra 9 11-11-2003 06:14 PM
Electric Supercharger P11GT Engine 7 10-02-2002 02:02 PM
Electric Supercharger - Interest Poll mwillmon Forced Induction 11 09-30-2002 08:39 AM
