Old 01-09-2004, 04:35 PM
tsugsr tsugsr is offline
Maintance Required light blinking to much
ok, i drive a 95 GSR, its got 79K on it, when i start the car, anytime of day, all the lights blink and stuff is fine, but the maintance required light thingy blinks about 10-11 times, it only blinks on start up and never blinks again, it seems like it blinks to many times. does anyone know what this means?? i wanna make sure its nothing serious or if it is then i need to get it to a shop asap. any help is appreciated.
Old 01-09-2004, 04:53 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Maintance Required light blinking to much
It will start staying on all the time soon. It is just reminding you that it has been on for a while. You need to reset it. Look under the dash and you will find a box with a button in it press and hold this button until the light goes out.
Old 01-09-2004, 08:52 PM
is it a "just for shits and giggles" light that acura puts in there? or is it trying to tell me something?
Old 01-09-2004, 09:10 PM
whtteg's Avatar
They put it there to remind you to bring it back for service. Have you had the engine coolant changed? It is supose to be done at 75k and then you will need to get your timming belt and water pump hanged and the valves adjusted at 90k.
Old 01-10-2004, 01:43 AM
BullShifter's Avatar
Re: Re: Maintance Required light blinking to much
It's there because most people think maintenance is not needed. Proper maintenance is key* There is no reason to skip/late the timing belt replacement, for your own sake replace the water pump. The light comes on about every 7500 miles
Customer brings in a car for t/belt replacement & declines w/pump. 3 months later the water pump goes & all that shit needs to be taken apart again & replaced, including a new timing belt. You just paid, what, 2 times the parts & 10 hrs of labor - not good.
Old 01-10-2004, 02:52 PM
whtteg's Avatar
Re: Re: Re: Maintance Required light blinking to much
I also like to change the crankshaft seal and the cams seal as well when I am doing it. But I am the only person that works on my car
Old 01-10-2004, 05:29 PM
ok good, ill look into getting the coolant replaced, when we bought the car my dad took it to a local, very good honda shop and had the crank case seal, timing belt, and water pump and a few other things replaced for added reliability and what not.
Old 01-10-2004, 08:12 PM
The coolant should have been changed with the water pump, but it won't hurt to check. Another thing, Honda/Acura brakes should be serviced every 15K or so, Honda recommend 7500 miles. Basically take them apart, clean, inspect, lube, *adjust*(drum), & compress pisonts.
Old 01-11-2004, 02:23 AM
ill look into the brake thing as well, thanks for yalls help, ill let yall know whatever i find out, it may not be for a couple days though
check engine light on and O/D off light blinking frpthlgy Sephia 17 05-03-2016 04:39 PM
Oil light blinking clemsonfansc Intrepid 7 03-02-2011 06:47 PM
Brake light/battery light blinking gallowsa Altima 1 06-06-2007 06:49 PM
4x4 lights not lighting/blinking craigndee Explorer | Explorer Sport Trac 1 08-07-2005 09:25 AM
maintanence required light blinks then goes out... ??? 94tegRS Integra 13 02-22-2002 03:03 PM
