Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-09-2004, 12:25 PM
torp3do torp3do is offline
Question RPM's Problem???
Hey Guys what's up???
Anywayz After going on a long drive from Vegas My 5th Gen lude SH started to act strangely when i try to rev up my engine...
Here's whats happening.... At neutral when i press on the pedal and rev it up the RPM's climbs up fine... but when i try to shift to first gear then run RPM tends to go up and down on me.... then when i shift to second it will do the same thing... so pretty much Looks like my cars power is dropping and its taking a hella long time to pick up.... Could this mean that its time for a new clutch or is there any problems with my Cars engine.....?????
Here's the Mods that I have on the Car so far...
AEM cold air intake
AEM Pulley
VTEC controller
Magnaflow exhaust
Any help will be appreciated thanks...
Torp3
Old 01-18-2004, 10:44 PM
tonymontana tonymontana is offline
Re: RPM's Problem???
sounds like your clutch is slipping, which means its FUCKED! Time to buy a new clutch.
Old 01-19-2004, 08:09 PM
Sacker90 Sacker90 is offline
Send a message via AIM to Sacker90
If its hesitating and jumping around its your distributor
Old 01-19-2004, 10:47 PM
Thanks yall for your response yeah i fugured it was my clutch i just needed some extra opinion....anywayz i bought the 4 puck act xtreme plate clutch kit I was kinda debating between the 6 and 4 but got d 4 puck since it says on their website that 6 puck is not recommended for street use... WHAT U GUSY THINK???? Oh by the way should i change my flywheel as well or should i wait.??
Old 01-19-2004, 11:41 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
i'm not sure 4 puck is recommended for street use either LOL
but whatever floats your boat
btw, its not ABSOLUTELY essential that you change your flywheel, but if you can afford it, do it. otherwise, it'd be a good idea to have it resurfaced. I'm pretty sure most brake shops will be able to do this for you at a good price.
Old 01-20-2004, 08:06 PM
Well yeah thats what my friend told me about the 4 puck as well.....
Suckin place said that 4 puck is okay..oh well....Thanks for all you help peeps....
Oscillating RPM's Problem 00GTP4ME Grand Cherokee | Grand Cherokee SRT8 3 06-23-2009 08:09 AM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
high RPM's problem silverado4X4 Silverado 6 05-13-2006 08:56 PM
