Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-08-2004, 07:30 PM
manyhoot manyhoot is offline
abs light
during the past summer I hit one huge bump on a highway with my 95 2500 and my abs light came on and also the brake warning light. since then i have been unable to figure how to get them to go out. the brake system is fine. I thought it might be the sensor on the master cylinder but that is fine too....any ideas
Old 01-09-2004, 02:06 PM
fahrfrumwurkin55 fahrfrumwurkin55 is offline
Re: abs light
my truck had that problem too.. only i dropped mine 6" in the rear so i think that's what caused mine..
i have heard people say that there's a switch near the brake pedal that goes bad..
oh, also if you ground out pin 13 on the OBD connector, it will send the ABS computer into diagnostic mode similar to the check engine light mode..
it turned out that my proportioning valve in the master cylinder was bad and it was sending most of my brakes to the front..
Old 01-10-2004, 06:20 AM
thanks for the suggestions...fahrfrumwurkin55
i will have another look at the problem and maybe have a solution now
Old 01-10-2004, 08:22 AM
Blastin Turkeys Blastin Turkeys is offline
Change the ABS sensor in your pig....
Mine stayed lite ...replaced it no problem!
Old 03-22-2004, 08:21 AM
bradley bradley is offline
My brake warning light and abs light were on, and I changed the rear wheel speed sensor and the brake warning light went off, but the abs light is still blinking, any ideas on what could be wrong or how I can fix the problem.
Old 03-23-2004, 12:42 AM
oldlion75 oldlion75 is offline
Re: abs light
My 2000 model 1500 4WD's ABS light and brake light comes on after I drive about 10 to 15 miles down the road. Once I turn off the truck and restart it both lights go out and stay out till I travel another 10 or so miles. I can not believe that I need to replace anything and I've checked all my wiring for loose connections. What gives?
Old 04-21-2004, 11:39 PM
write off write off is offline
Re: abs light
I have a 99 and had both my brake warning and abs lights come on. Speedo only worked at speeds above 40mph. Changed out speed sensor and fixed the light problem and speedo problem
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
'95 Town car ABS light on and hesitation olopezm Town Car 5 12-02-2010 06:30 PM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
95 silverado abs light is on and smells like brakes joseriverasg Silverado 2 12-21-2009 10:15 AM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
