H&R OE Sport or Neuspeed SoftSport springs?
I don't want to lose much ground clearance but I want to improve handling, and keep a resonably smooth ride so I'm considering:
- H&R OE Sport springs - Neuspeed SoftSport springs - something else? Comments? Suggestions? |
Re: H&R OE Sport or Neuspeed SoftSport springs?
H&R, a lot of people I know are running H&R springs and they all love them
![]() Empty Pockets Racing Member #1 |
I read a bunch of reviews saying that practically every aftermarket spring sagged after awhile. Anyone have this experience?
The H&R EO Sports sound good because they only lower by 0.75, have been reported to give "just as good a ride as stock" but still improves performance. |
Re: Re: H&R OE Sport or Neuspeed SoftSport springs?
True full coilovers don't sag after time. At least my Tein SS's didn't after I got them, and my new stiffer springs I got for them a few months ago haven't sagged or settled much if any either.
Silver '00 Civic EJ6 Coupe PureHonda original member since Feb. 2000 D-series revolution For pics of my baby, click here! All rights reserved... All BITERS served! "The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket." i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift hessemer69 on AIM |
Both are good choices, I'd get H&R before Neuspeed. If you looking to increase handling, a sway bar upgrade is just the thing you for since it doesn't affect ride quality. Focus on the rear bar first, then you may want a different front bar or just upgrade the stock front sway bushings end links to poly. I also suggest aftermarket struts to be used with ANY aftermarket lowering spring.
http://www.suspension.com/stam-bar.htm Upper & lower strut/tie bars don't do as much you would think. 1 larger rear sway bar will do more than all 4 ties bars together, however it's recommended to use a lower rear tie with an upgraded rear sway. Chimchim - ALL springs "settle" some more than others. |
Oh... I'm already doing the rear sway bar. So the suspension would come after.
I guess I should get new shocks along with the new springs? (I've got 84k miles on mine) |
I would do the springs/struts first, but the order doesn't really matter. Yes, you should get new aftermarket "performance" struts. If I were to lower a brand-new car, say 10 miles, I'd upgrade the struts. Basically struts/shocks control springs, with "lowering" springs the spring rates are increased. Stock struts/shocks can not control the springs properly, they over work usually resulting in a blown seal & premature wear is a given. My best advice, replace the struts & springs together. This way it's only taken apart 1 time & 1 alignment.
