Old 01-08-2004, 05:08 PM
mpk78 mpk78 is offline
Question 1993 Chev Truck no VERY COLD start
I have a 1993 Chev Truck K1500 4x4 with a 4.3L V6 Throttle Body. Problem being when it gets REALLY cold it will not start unless you start touching the throttle. Without touching the throttle it will crank all day. Warmer weather starts 100% and after truch has been starter it starts fine. I have replaced Cap, Rotor, wires, plugs, gas filter, air filter, pcv Valve, O2 Sensor, Coolant Sensor........Please help
Thanks
Old 01-14-2004, 12:28 PM
toivo toivo is offline
Re: 1993 Chev Truck no VERY COLD start
check for fuel pressure. also check all your vacuum lines for leaks. check vacuum when idling. sounds like its not getting fuel.
