Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-08-2004, 09:07 AM
mrsparky637 mrsparky637 is offline
Angry 96 Grand Marquis help!
My 96 Grand Marquis will whistle when started on cold mornings.After motor runs for a while it will eventually quit. I changed the fan belt, but still does the same. Just on when it is cold outside. Any Ideas? I recently put in 4 new bosch oxygen sensors, but the check engine lights comes on and stays on periodically. I had it scanned at auto zone and it shows the same codes each time. PO 171 and PO 174. Does anyone have any ideas why this is happening and what do I have to do to fix it? Any help would be greatly appreciated!
Old 01-09-2004, 03:05 PM
MercCougarXR7's Avatar
MercCougarXR7 MercCougarXR7 is offline
Re: 96 Grand Marquis help!
What do P0171 and PO174 mean? Having a code number doesn't help if you don't get the explanation of what the code is.
The whistling could be your belt slipping, my 92 did that all the time - especially when it was cold, or when I went WOT with it.
About the motor quitting, how does it run when it's first fired up before it quits (lumpy, low idle, fuel starved)? Might be Idle Air Control motor?
2000 LS8 Sport, 1992 XR7 5.0 HO
Old 01-10-2004, 05:48 AM
Re: Re: 96 Grand Marquis help!
I'm pretty sure its not the belt. You can hear it coming from the motor. I cant hear too well, so I can't pinpoint the location. The best I can rember on the codes(PO 171, PO 174) is for running lean on bank 1 and bank 2 of motor. Two for each side.
I was told that they were for Oxygen sensors, so I replaced with 4 new Bosch. Thank you for your help
Old 01-17-2006, 12:34 PM
96marquisboi 96marquisboi is offline
Send a message via AIM to 96marquisboi
my did the same and it was a squeky belt because the cold makes it hard and when it starts then the belt isnt on track. but when the engine heats up the it gets soft and goes on track. its normal when ur belt is older so if u HATE this then get a new
Old 01-21-2006, 07:46 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Your codes may be from a dirty MAF Sensor. Clean or replace it. Also check all the hoses/connections that go to it for leaks or cracks.
Whistle could be an air leak, maybe the IAC valve or you may have to do some more poking around to find the problem?
http://www.v8sho.com/SHO/TSB982310Ma...tamination.htm
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
