Old 01-08-2004, 03:17 AM
bergerac54's Avatar
bergerac54 bergerac54 is offline
removing CA
Was working on a side project today (not car related) and managed to get a big CA fingerprint on a piece of textured plastic which isnt going to be painted. Can anyone tell me how to remove CA from plastic without sanding???
Old 01-08-2004, 05:03 AM
David_ David_ is offline
Re: removing CA
what is ca? and like..... is it moulded in? or is it just an impresion?
Old 01-08-2004, 05:17 AM
chrismcgee's Avatar
chrismcgee chrismcgee is offline
WWW.ELITESCALECARS.CO.UK
cyno acrylate (i think its spelt like that) its superglue in common terms.
you could maybe try tooth paste or automotive polishes? dont hold me to that. or 2000+ grit sand paper then spray it with clear to give it shine again
Old 01-08-2004, 05:22 AM
Re: removing CA
there should be some harsh chemical substance that could remove it... otherwise.... slowly file it away.... without ever touching the plastic, then when u get down to the end, pick it off with ur nails....
Old 01-08-2004, 09:55 AM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Re: Re: removing CA
Why would you want to file it when you can easily sand it off? Using a file is harder then using sandpaper, also there is a chance of messing up your model at the same time. cmon man dont tell people bad tips you used on your model that is now messed up.
You can start from 800 Grit and work your way up to like 2000 or 3000. It should go away quickly.
Old 01-08-2004, 11:48 AM
cogitator56 cogitator56 is offline
Send a message via AIM to cogitator56
You could also try using a CA debonder. Since it disolves the CA when I accidently glue my work to my fingers, it might disolve the CA on your piece of plastic. Then you could just wipe it away without having to use an abrasive. I'd test it on some scrap plastic first though, to make sure there aren't any bad reactions.
Old 01-08-2004, 12:21 PM
V1nce V1nce is offline
try nail varnish remover
Old 01-08-2004, 02:48 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Use any product containing Acetone. It dissolves the CA, and should remove it. Apply it sparingly, a little at a time, and it will slowly dissolve away. Don't bathe the fingerprint in the acetone, it can possibly damage the plastic. Nail polish remover contains acetone, but check the label, some of the new "softer" varieties do not.
Old 01-08-2004, 08:25 PM
falbert19 falbert19 is offline
There's a debonder called Z-7. You can find it here:http://www.micromark.com/
Old 01-08-2004, 08:45 PM
bergerac54's Avatar
Thanks guys
Old 01-09-2004, 09:59 AM
Murray Kish Murray Kish is offline
Getting Old...
Re: removing CA
Sounds like you've got the answer already, but I'll add my thoughts anyways:
1. As mentioned, try CA debonder.
2. I've found that if you put the part in the freezer for a while, the CA will become extremely brittle. You mentioned that the part is 'textured', which makes removal a bit more difficult. But after it comes out of the freezer, try just prying the glue away with a toothpick. If you're lucky, the glue will just pop off.
Hope it works!
Murray
Remove 94 APV rotor removal (How to?) djjimmer Lumina 0 07-16-2004 08:42 AM
Removing distributor during tranny removal dagoEF '88 - '91 Civic | CRX | Wagon | Shuttlee 3 05-13-2004 11:19 AM
'94 Jimmy Dash Removal (attempting to remove heater core) Blind Squirrel Jimmy 1 05-09-2004 11:32 AM
how to remove air cleaner to remove battery jimdandy45 Lumina 1 01-10-2004 01:22 AM
93 Cx A/C removal & fuel / other lines. Engine Removal Pt.2! **56k grab a pillow** Hybrid93Hatch '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 03-05-2003 07:52 AM
