Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-08-2004, 01:10 AM
pnavarro pnavarro is offline
5 speed manual transmission problems
I'm the 2nd owner of a 99 Rodeo LS with a 5 speed manual tranny with 88K on the clock. My trans has been getting progressively noiser in 1st, 2nd, 3rd, fifth and reverse, strange as it is, I get no noise in 4th gear.
The noise started about 2 months ago, very slight at first but now it sounds like a cement mixer going down the road.
BTW sitting idle, engine on in neutral I get a similar noise, just a bit quiter, i get no noise with the clutch in.
Has anyone else experienced this?
Does anyone have any ideas what the problem is?
I assume the obvious answer would be the clutch and or pilot or throw out bearing, but I can't explain how 4th gear is quiet!
Thanks in advance for any help.
Old 02-13-2004, 11:32 PM
geg geg is offline
Cool
Your problem is that your main input bearing is going south. I have found that the transmission shop is your best fix. Get a total bearing rebuild kit installed. I have done this job myself a couple of times and always run into problems pulling bearings from shafts. You want to get this fixed as quick as you can. The bearing junk running through the gears is not good for your unit.
Old 07-06-2004, 07:27 PM
dinanaylor dinanaylor is offline
Send a message via Yahoo to dinanaylor
question about your problem
OK, is the noise a whining, but loud? Mines been doing the same and someone said it may have been the throw out bearing, today my gears locked up, and No more drive! Same problem? Just mines totally broke now?
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 04:49 PM
Funny thing in a '02 Ford Explorer Sport 5-speed manual transmission lidation Explorer | Explorer Sport Trac 1 05-01-2007 01:31 PM
5 speed manual transmission problem. svoruz Ranger | Courier 3 11-04-2004 09:38 PM
