Old 01-07-2004, 11:28 PM
xlwhellraiser xlwhellraiser is offline
Send a message via Yahoo to xlwhellraiser
few starting questions firebird 79..?
When I start my bird (when its cold) it chokes and than stabilizes after 2-4 min. Than however, my engine runs faster and I have to give it gas to put it in normal runing condition. i was wondering why is this happening.
When its not cold, it usually starts out fast, but than I give it gas to slow it down.
By fast I mean kind of like louder and as if somebody is giving it gas.
I heard about hot starts but I was not sure if this is it.
Thanks for the help guys.
Old 01-08-2004, 09:31 AM
Vlad_Tepes's Avatar
Vlad_Tepes Vlad_Tepes is offline
Re: few starting questions firebird 79..?
Sounds like idle problems...
Yeah yeah I know it looks like grandpa's but wait til I put the LT1 in it
Old 01-10-2004, 12:56 PM
Philo Philo is offline
Without more info, and a more precise description of the problem, I can tell you that carb equiped autos have an automatic choke. Part of this mechanism is a fast-idle cam. When you start the auto cold, you need to press the throttle about half way down one time before cranking to set the choke. At the same time, the fast idle cam sets to make the engine run faster so it won't stall while warming up. The Pontiac 400/four barrel in the '79 TransAm will run at about 1800 rpm after it warms up. To slow it down, you tap the throttle to release the fast idle cam. Then the throttle will go back to the normal idle stop and the engine will slow down. When hot, the engine does not choke and does not move the fast idle cam. By hot I mean running within about the last two hours on a warm day, or about twenty minutes when below freezing.
1996 Pontiac Firebird, Security Problem, Please Help, dshoema2 F-Body Problem Diagnosis 1 01-12-2010 11:31 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
couple questions about 79 TA brass_monkey93 Camaro Discussions 4 02-26-2007 06:24 AM
Cold starts take a few starts GT500916 Technical 5 03-19-2006 07:51 PM
heating question for 79 firebird formula. xlwhellraiser Camaro Discussions 4 12-19-2003 12:45 AM
