Old 01-07-2004, 10:16 PM
BlueBurr BlueBurr is offline
Send a message via AIM to BlueBurr
Flamethrower Kit ?'s
Ive got a flamethrower kit and i was wondering if your fuel ratio had to be at least a 10:1 ratio for it to work ,I bought a Vortech 12:1 ratio FMU and i dont have a cat?
Old 01-20-2004, 01:40 AM
IntegraB18LS's Avatar
IntegraB18LS IntegraB18LS is offline
do you have a turbo or supercharger? 12:1 means it raises the fuel pressure 12 psi for ever 1 psi of boost, if you dont have boost it will not rise the pressure.
[url=http://www.automotiveforums.com/vbulletin/showthread.php?
1995 Honda Civic EX
-Integra B18B1 LS engine
-Turbocharged
-Rear disk conversion
-Many mods
Cheak out my civic (cardomain)
Easly got 10k into this car with everything and it still looks like a POS
Old 01-22-2004, 09:14 PM
Re: Flamethrower Kit ?'s
no i dont but i plan on getting it turbocharged soon,as fast as i can,
Old 08-08-2004, 02:55 AM
I-Eat-Civics I-Eat-Civics is offline
Send a message via AIM to I-Eat-Civics Send a message via MSN to I-Eat-Civics Send a message via Yahoo to I-Eat-Civics
where did you order your kit? The one im getting uses a spark plug and coil.
www.autothisworld.com
saw it in a add in the new sport compact car mag. the one with the 9 sec supra. damn its amazing
The 91 LS no Longer Lives www.RIP91TEG.piczo.com
__________________________________________________ ___________
1995 Acura Integra GS-R:
Blown Motor Waiting for swap
Old 09-29-2004, 02:58 PM
ShoX8517's Avatar
ShoX8517 ShoX8517 is offline
u can make one ur self, put a spark plug in each one of ur mufflers and run a wire from the coil to them...but make sure to but a in line togle so u can turn it on / off
Old 10-14-2004, 09:49 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Propane injected into the exaust near the end and a spark plug ran to the coil is the easy way to do it. if you are a good electrician you can make it come on when ever your rev the car up to a certian RPM then drop off the gas... using propane is alot better for your engine because you dont have to run it hella rich. but then aagian flame thrower kits are kinda retarded because engines are sapposed to be spitting fire everywhere...
Old 10-18-2004, 07:54 PM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
10.1 Air fuel? Thats a little rich, yeah, I heard that benzonmatic propane/mixture stuff works pretty good too...
Old 10-21-2004, 12:28 AM
hearsedriving fool's Avatar
hearsedriving fool hearsedriving fool is offline
most of the flame kits you buy out of a mag ad go in line of you spark plug wires, they kill one or two of your cyls to shove more fule through the exust. the spark that would be going to the combustion chamber is seent to plugs you install in you exoust pipe (about 5in or so from the tip) this is BAD! the unburnt fule can wash the oil from your rings thus caulsing more friction, wearing out the rings faster.
ive played with the propane injection methed. the problem with coil togel methid is the coil only fires whin you turn off the switch. so you git a very cool blue ball of flame. the easest way i came up with fixxing the switching prob is a blinker (turn signal). if you use one with 3 prongs 2 coils could be used. (i havent got around to trying the blinker but it should work)
hope that helps ya out or gives ya some idias
james
(i failed spelling if you couldnt tell)
Old 12-05-2004, 10:58 PM
454Casull 454Casull is offline
Re: Re: Flamethrower Kit ?'s
If this is true, why aren't rings failing left and right? We all know that there is unburned fuel for 2 of the 4 cycles (2 and a quarter, really), so why would 2 more make a big difference? Also, the "problem" is even worse when people run rich, but you don't see them complaining about their piston rings too.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 12-14-2004, 10:37 PM
adrenalinejunkie76's Avatar
adrenalinejunkie76 adrenalinejunkie76 is offline
Send a message via AIM to adrenalinejunkie76 Send a message via Yahoo to adrenalinejunkie76
this is prolly a stupid ?, the car that im building is going to have exoughst that is coming out the side, right b4 the back tire, is it safe to put a flamethrower on it?
76 CHEVY VEGA
Old 12-14-2004, 10:39 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
i read if u hook the kit up wrong...either homemade or store brought...it can make ur muffler come flying off
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 12-20-2004, 08:42 AM
foureyedbuzzard foureyedbuzzard is offline
Why dont y'all just use a propane bottle, pipe or hose to 12v solenoid valve, pipe or hose to exhaust just after cat(s). Fire an old ignition coil off the same signal you use to the solenoid valve(s) ???
If ya can't figure it out ya prolly shouldn't be doin' it!!!
Old 12-20-2004, 08:42 PM
98 SNAKE EATER 98 SNAKE EATER is offline
Send a message via AIM to 98 SNAKE EATER
Re: Re: Re: Flamethrower Kit ?'s
Sorry, but that will never work unless you use a Model A/T Buzzcoil.....
It takes a bit more than just a simple 12 volt lead to fire a modern ignition coil....
I agree with'ya on this one
Fiberglass Kit for 1997 Aerostar teakstone Aerostar 1 09-25-2009 08:10 PM
For Sale: Turbonetics Spec V turbo kit 04-05 $3400 TeamTurbo Sentra | 200SX (USDM FWD) 2 08-05-2009 01:54 PM
94 Bravada Lift Kit Xodus989 Interior | Exterior | Appearance 2 03-10-2009 08:47 PM
Propane Flamethrower Kits ChickMagnet869 Street Racing 19 04-13-2004 07:21 PM
