Old 01-07-2004, 07:06 PM
fletch_1958 fletch_1958 is offline
Unhappy Window Crank
what in the world am i doing wrong? How's this thing come off? oh yeah, it's 95 grand am.
Old 01-08-2004, 01:39 PM
justin0419 justin0419 is offline
Window cranks have a retainer clip on the backside of the crank. Go to an auto parts store and pick up a window crank removal tool.
Old 05-24-2004, 10:54 PM
derffred's Avatar
derffred derffred is offline
Re: Window Crank
Another way to get the crank off is to take a rag and while holding it with both hands slide it between the crank and the door panel, slide the rag from left to right and back and it should grap the clip and pull it out.
sometimes it works right away and other times it will take a while.
Old 05-26-2004, 08:14 AM
GASE 95 GASE 95 is offline
Re: Window Crank
i just used a screwdriver and stuck it in between the crank and the door panel and used it like a pry bar so that i could see the clip holding the crank in place..after that a pair of needle nose plyers will do the trick. Ya might hafta push the clip from the bottom to get it to stick out enough at the top to grab onto with the plyers...also might need someone to hold the screwdriver in place just so you have an extra free hand
Anti-Theft Window Crank Device ? Intuit Escort 6 10-11-2011 02:00 PM
window crank XtremeRider16 S-10 3 06-04-2004 08:39 AM
Window Crank ga11sport Sephia 1 10-22-2003 04:07 PM
Help! Need window cranks! Faene Off-Topic 1 10-09-2003 01:11 PM
Window Crank Removal and Replacement moleodonuts '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-09-2003 10:29 PM
