Old 12-23-2001, 12:31 AM
Hybrid Boy's Avatar
Hybrid Boy Hybrid Boy is offline
Banned
Send a message via AIM to Hybrid Boy
Is this bad for the clutch?
Ok, im not totally sure here... But I was wondering... When i want to get good MPG, i usually shift @ 3g's.. And I usually drive in 5th gear when I am going like 35mph. (my car usually revs around 2gs then) I waswondering if this is bad for the engine or the clutch? I dont accelerate when im at low rpm, only for steady driving. is this bad? Or should I be in like 4th gear @ 35mph so im at 3g's? J/W
Old 12-23-2001, 12:37 AM
CivSiGuy's Avatar
CivSiGuy CivSiGuy is offline
Banned
Send a message via AIM to CivSiGuy
no.. its fine. I drive like that around the city alot.
Old 12-23-2001, 12:44 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
your either connected or your not.
connected = good
not connected or slipping = bad
some people will argue the torque loads in certain gears at given rpm's but i think its bullshit. obviously dont gun it in fifth gear going 40 but other then that if your just cruising then its no big deal
Old 12-23-2001, 11:41 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
on a stock or near stock motor, it doesnt matter what speed you're doing or what gear you are in. it doesnt affect the clutch at all.
the friction plate merely bonds the flywheel to the tranny... no matter what speed or gear you are in. if you're in too high of a gear, the motor may bog. the only time clutch wear comes into play is if your motor is making more power than your friction disk and pressure plate are rated to hold... like going turbo on a stock clutch... the motor has enough torque to spin the flywheel and break the bond between it and the friction disk, thus causing clutch slippage, and galzing of the disk and preventing a solid lockup and transfer of power to the wheels. or if the pressure plate is too light, the friction disk will bounce off the flywheel, causing clutch chatter when accelerating due to the motor overpowering the clutch assembly.
go to www.howstuffworks.com and learn how a transmission works.
Old 12-23-2001, 02:03 PM
AznRide's Avatar
AznRide AznRide is offline
Send a message via AIM to AznRide
This is what exactly happened. My so call lil Jess up there said that because of the snow and slippery road, he goes 25 mph in 4th gear because he might think his lil over powered civic gonna fly off the road or something. I told him if he goes like 25 mph in like 2nd gear or so, he would get better traction in the snow. Also, that's why people downshift a lot in the snow for better traction because honda civic has fwd, so when you downshift for braking purpose, most weight will be transfer in the front which give the front tires better tractions. SO by going 25 mph in 2nd gear on an icy road...if you feel the road is slippery, all you do is simply let go of the gas and the weight will be transfer in the front for better traction. Right? Correct me if I'm wrong. What's the point of going 4th or 5th gear in the snow at 25 mph? Of course people do that in the SUMMER when cruising but in the snow?????
"I never had a dream come true, 'til the day that I found you, even though, I pretend that I've moved on, you'll always be, my baby..."
- S Club 7
Old 12-23-2001, 02:10 PM
Hybrid Boy's Avatar
Banned
hmmm..... I dont remember saying to you my "overpowered civic" or anything to that effect My point was the roads were so slippery and all, that i was able to spin my tires in 4th gear @ 25mph by tapping that gas. I simply tried to start a convo about how bad the roads were. then he goes and says im stupid for driving in 4th gear @ 25mph...
Old 12-23-2001, 02:44 PM
AznRide's Avatar
"I just tap on the gas and it's just ...." If you car ain't that powerful, then just a tap, it would do that? GGRR, I have nothing else to say...but you are smart, very smart boy.
- S Club 7
Old 12-23-2001, 08:26 PM
drift's Avatar
you're wrong.
it's better to maintain a high gear in slippery situations cuz gearing multiplies torque. the higher gear, the less torque is multiplied. therefore, the less torque at the wheels. by using a higher gear and thus putting less torque to the ground, you reduce the chance of breaking traction due to hitting the accelerator too hard.
think about why you cant chirp your tyres in 5th gear... not enough torque to the wheels after gearing converts it.
thus using a higher gear in slippery conditions is safer due to less chance of wheel slippage from throttling. the traction would be the same in any gear, but a lower gear would give him more effective torque at the wheels, increasing the chance of breaking traction when throttling the car.
as for downshifting in snow... unless you know how to rev match the motor, you'll run the risk of breaking traction. ever downshifted just by easing off the clutch? it forces the car to slow down fast since the motor is forced to move the same speed as the transmission... if traction is low, then the motor would force the tranny and wheels to spin faster, and not vice versa, thus causing tyre slippage and loss of control. if you rev match, then you can safely downshift without losing traction in snow.
the downshift theory doesnt work for you in this case... cuz once you hit the brakes, the weight transfers forward, regardless if you downshift or not. downshifting will not transfer any more weight than braking... you can always step on the pedal even harder.
as for just letting off the gas in second on an icy road, the tranny and thus wheels having to suddenly stop accelerating will possibly cause a loss in traction due to jerkiness... ever done that in second gear before on dry pavement? the car jerks kinda hard...
in a higher gear, the car wont jerk as hard when you let off the gas, thus maintaining traction.
in this case, hybrid boy is completely right in doing what he does in a low traction situation.
Old 12-23-2001, 09:34 PM
CivicEx95's Avatar
CivicEx95 CivicEx95 is offline
Banned
Send a message via ICQ to CivicEx95 Send a message via AIM to CivicEx95
the only time there is wear on the clutch is when the flywheel and clutch disc are connected and spinning at different speeds.
Old 12-24-2001, 11:32 AM
Whtehnda93DXSdn Whtehnda93DXSdn is offline
Send a message via AIM to Whtehnda93DXSdn
not at all..keep on doin what you do....
:frog: :frog: :alien:
another good honda site:
www.civicland.com
Old 12-24-2001, 11:44 AM
spnx's Avatar
spnx spnx is offline
I wouldn't do it in a reardriver - it's hard on the universal joints to be lugging it in too high a gear. However, in a FWD car, I agree, it's fine.
