Go Back   Automotive Forums Car Chat > Cadillac > General Discussion
Old 01-07-2004, 03:21 PM
mike1236 mike1236 is offline
Question remote keyless entry
I was given a fob with the following numbers on the back. GM 09378610 -- Canada 26861021384 -- Model /FCC 10 L2C0005T. It is a #2 unit. I think it came from a 2003 Cadillac but not 100 persent sure.
Does anyone know what autos this would work on when programmed? Is there any where on the internet than one could plug in the numbers and it would tell you which autos it would work on? Would appreciate any advise you can offer.
Mike
Old 01-07-2004, 06:43 PM
Accordability's Avatar
Accordability Accordability is offline
from my understanding... that's easy enough to get from your local Cadi dealer.
1992 thru 1995- #1) 10269729 #2) 10178734
1996 and 1997- #1) 16183016 #2) 16196066
1996 and 1997- #1) 16259819 #2) 16259829
1998 thru 2000- #1) 25656444 #2) 25656445
2001 to Current #1) ? #2) ?
the above info i found at: http://209.145.176.7/~090/awh/cad98rke.html#trans
hope this helps
Old 01-08-2004, 02:14 PM
Re: remote keyless entry
Many thanks for the reply. I tried the dealer and he didn't offer much help. I'll keep searching and maybe somebody out there knows who manufactuers these things and I can contact them.
Old 07-12-2005, 02:39 PM
ckaplin ckaplin is offline
Send a message via AIM to ckaplin Send a message via MSN to ckaplin Send a message via Yahoo to ckaplin
Re: Re: remote keyless entry
You may have already found out but it should work on any OBD2 GM vehicle, it will need to be programmed by a dealer and u really should have the number 1 fob also but it shoudl work stand alone
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
'09 Corolla KeyFOB, keyless entry programming Question btrolla Corolla/Matrix/Voltz 1 09-03-2010 12:00 PM
1991 OLDS Cutlass Supreme SL 2-door keyless entry module PAPAJACK Cutlass Series 0 07-31-2010 09:56 PM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
