Old 01-07-2004, 10:31 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Thumbs up Set timing after putting head back on? HELP QUICK!!
I just put the head back on my engine and have a question about putting the timing belt back on. I know how to make sure that the cam is in the correct position but how do I make sure that the crankshaft is where it should be? I want to get as much done today as I can so please help me asap!
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-07-2004, 10:42 AM
91civicDXdude's Avatar
on the crankshaft pulley there will be four marks.
like this. the one mark by itself is TDC. line it up with the little sight on the timing cover, which is located to the rear of the engine mount.
Old 01-07-2004, 10:45 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Did you mark the cam gear & timing belt before you took the belt off? If I'm not mistaken, you're supposed to set the cam gear at TDC before removing the head. Most people mark the belt & gear with White Out, or chalk so you know exactly where the belt was on the gear when you took it off...
Old 01-07-2004, 10:56 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Set timing after putting head back on? HELP QUICK!!
If you look at the timing belt gear on the crank, it has a little notch that you need to line up with the little timing mark.
Old 01-07-2004, 11:07 AM
Re: Re: Set timing after putting head back on? HELP QUICK!!
If I line it up with that 4th mark (the white one) then the little notch in the gear should be lined up too right?
ZC stuff
Old 01-07-2004, 11:17 AM
JimCRX's Avatar
JimCRX JimCRX is offline
I'm in the process of doing my head too man. I'm waitin for it to get pressure checked at the machine shop. Did you take the whole timing belt off? Or just the part for the cam gear? Cause I set both to the TDC marks. I tied some of those twist tie thingys on the gear so it wouldn't move and took a lot of pictures. Makesure that everything is set just the same as when you took it off. You shouldn't have to move anything.
Old 01-07-2004, 11:56 AM
Alright thanks, I got it now. It wasnt too hard. Jim (im taking a stab in the dark that thats your name) if you need any help when you put yours back together, pm me. I definitly understand it now.
ZC stuff
Old 01-07-2004, 06:27 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
i am pretty sure jim knows what he is doing if he explained it to you man...lol
Old 01-08-2004, 08:57 AM
JimCRX's Avatar
Lol, this is my first head I'm doing. I read up on a lot of stuff and talk to some experienced people. So it's basically like a try n miss for me. But I'm sure I'm heading the right way. My next mission is putting on this OBX intake manifold and jdm zc fuel injectors I have coming from ebay.
Old 01-08-2004, 03:30 PM
blade34609's Avatar
blade34609 blade34609 is offline
I already bought my head gasket and torque wrench today, because Friday I will be replacing it.
So you guys are saying that yuo will have to mark where the TDC is b4 u take the head off?
Also, Im just takin part of the timing belt off, jus enough to get the head off the block thats fine right?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 01-08-2004, 05:36 PM
you can do it one of two ways really..
1. turn the crank to TDC by the TDC mark on the crank pulley. when you put the head back on, set the head at TDC, replace the timing belt.
2. leave the crank where it is at, leave the head where it is at. Using whiteout, or anti sabotage paste, or something similar, mark a tooth on the cam sprocket and mark the corresponding rib on the timing belt. remove the head (do not turn cam) & hold tension on the timing belt so that it doesnt slip out of the lower pulley grooves, then replace the head, line up the marks you made and have at it.
Old 01-09-2004, 12:04 PM
JimCRX's Avatar
There should already be a TDC mark on the on crank pulley. You need to turn the crank counter-clockwise and watch the pulley for the TDC mark. Commonly they'll be a white dash. Once you have that lined up with the pointer for the crank pulley, check the camgear to makesure the two lines are lined up level with the head and that the TDC line is lined up with the pointer on the timing belt cover. Check the rotor lineup too. The one part of the rotor will have a whole, find the #1 bolt whole and check if their lined up. Let me know if you need anymore info.
1991 Tbird - How to Put Tension Back on Belt After Alternator Replace Samsco Thunderbird 0 10-26-2007 10:53 AM
Urban-proof model to put Nissan back on the map - Times Online Automotive News Automotive News Desk 0 01-20-2007 04:50 AM
Davidson puts Honda back on top. - crash.net Automotive News Automotive News Desk 0 03-11-2006 05:10 AM
Why is warning light on, after putting new starter on Maxima? retracy Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 10-19-2005 01:56 AM
lifters making loud noise after putting engine back together titansgirl82 Grand AM 2 09-10-2005 12:58 PM
