Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-06-2004, 11:06 PM
russmnymn russmnymn is offline
sleeper??96 Integra
I have 96 intergra LS with stock engine and auto trans(yes auto).I'm not trying to race the world or be the fastest car but would really like a LITTLE pep in the step.I do have header and cat back exhaust.What I really want is nos at wot.Will this hurt my engine and what kind and how much should I go with.Do I use wet or dry?What size shot can the stock 1.8 lt take?And last thing I remember right now is when I hit 105 mph it won't pick up any more speed,any suggestions would be appreciated.If you install not when wot,does it spray until you let off the gas.I would like to also mention I would like the easiest nos to install and a kit that comes complete with everything to install.Thanx for all help
Old 01-06-2004, 11:14 PM
drake 60 drake 60 is offline
Send a message via ICQ to drake 60
Re: sleeper??96 Integra
sleeper? the Nitrous will help obviously but first I dont think it will help it enough to call it a sleeper?
... I dunno but my oppionion of a sleeper is like a Ford Escort or a Mazda 626 that runs 14's. Integras are generally quick cars (not fast but quick) and just by looking if there are no decals you wont be able to tell if the engine is a LS or a GS-R so for an integra to be considered a sleeper it would have to look bone stock and be mighty fast im thinking 13's even 14's with an Integra would be considered pretty good !
oh I almost forgot about the Nitrous thing , Im not a mechanic but I would think that just putting Nitrous in your car with absalutly nothing else in it would rip the engine apart ..no?
dont do nitrous , if you want a faster car , get a manual trans, intake headers ,and exaust , the three work well together and its not too much money or damage to your engine , compared to nitrous anyway, but if you have money id also go to a better engine GS-R or Type R
Old 01-07-2004, 12:06 AM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
You should turbo it. As far as nitrous goes, I've heard that your car can typically handle half the stock HP. So in your case a 70 shot, but I wouldnt go that high. Maybe a 55. WOT would be a good idea and minimize damage and wear. Wet vs Dry is an ongoing battle, but 75 and up seeing as how it requires more fuel, Id say wet would be good. A 55 or 60 should be fine with a dry kit if properly tuned.
Old 01-07-2004, 11:50 AM
What mods need to be done to computer to let it go over 104 mph?And to one of the replies-nos is cheaper than turbo-even though turbo would be sweet,thats why I just want low shot nos at wot.thanx for all post's
Old 01-07-2004, 07:26 PM
nyo91 nyo91 is offline
what??? ive got a 95 ls auto *bonestock* ran past a buck*twenty-five easily.
Old 01-07-2004, 08:34 PM
When My car shifts into 4th gear at 105 it don't pull or gain speed ANY,notta,none,and it don't matter how much gas I give 1/2 or wot it does not go any faster.HELP!!!
Old 01-07-2004, 09:26 PM
Oh yea it pulls steady to 104mph and pulls great,but seems like something is restrickting it from going any faster
Old 01-07-2004, 11:33 PM
integralover's Avatar
integralover integralover is offline
damn i have a 93 ls and i can get it up to 140 mph, i can go alittle more but with the stock rims it does not feel like it can handle that well. and i have intake, cat back, header, chip, and test pipe.
Old 01-08-2004, 08:28 AM
Re: Re: sleeper??96 Integra
prolly have some sort of restricter on it.
Old 01-08-2004, 03:45 PM
Teggy Pwnage Teggy Pwnage is offline
Send a message via AIM to Teggy Pwnage
How many miles are on the car, or do you beat on it? The clutch might be slipping a little...
Old 01-08-2004, 04:41 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Read more carefully he said it was an automatic tranny. I have no clue why it won't go over 104mph. That is really strange, I have never heard that before. As fas as the N20, nitrous, juice (not nos) goes if you are serious about the nitrous then go wet, if you just want a little pep every now and then get the dry kit. But I warn you once you get the juice it will become easier and easier to convince yourself to up the shot more and more. So I always suggest the wet kits. And yes your car can handle 75 hp shots. I have been running 65-80 hp shots for 2yrs now, it is all in the tuning, install and self control <--- this being one of the most important.
Old 01-08-2004, 08:23 PM
I have header and cat back exhaust,and thanx for pointing out to some that I did say it was an automatic.I will get true cold air intake soon(before installing nitrous)Where would some sort of restricktor be at?integralover what chip are you refering to?Teggy Pwnage the car only has 68,000 miles and not hard driven miles(yet).To all-the car just won't go any faster then 104 mph,any suggestion on what might be causing the restrickion-like ecm etc...I have a 95 integra that I might try swaping the ecm to see if it runs any better(this is just a car I picked up to turn around and sell.It was theft recovery(needs new dash wiring harness,cluster,brake work,body work and paint)Its just plane jane w/out abs or cruise.Are you able to put v tech head on this 1.8lt auto?Because I thought you can only use with manual trans(because of wiring harness)?
Old 01-09-2004, 12:18 AM
yea you can put v-tech on it. as long as it is a b18 which it is. the chip im referring to is a skunk2 racing chip. i ofund mine on ebay for about $20 including 3 day shipping. i do say that i got lucky to find a good person. though i did have to solder it myself. and the difference is very noticeable. and im just throwing this one out. my back calipers were sticking and i could not figure it out for about 9 months. thought it was everything else except the back. but i finally replaced them 2 days ago and my speed has picked up alittle.
Old 01-09-2004, 03:19 PM
whtteg's Avatar
You are not living up to your username very well It is spelled VTEC and that is the only way to spell it. I don't think your car has one of these
Old 01-09-2004, 03:28 PM
Oblivian Oblivian is offline
Send a message via AIM to Oblivian
haha
96 Integra Emerald Integra 3 12-08-2003 11:49 AM
96 Integra LS (AUTO!) vs 96 Grand Prix (auto..) SmellBurntRubber Street Racing 5 10-26-2003 10:43 PM
0-60 time for a 96 integra gsr k2nride Integra 6 04-08-2002 10:28 PM
96 Integra GS-R or 240 SX? jonk37 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 18 03-28-2002 08:54 PM
