Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 01-06-2004, 07:42 PM
krdragon krdragon is offline
Unhappy VW Golf No Start
I have 1997 VW Golf that will not start. Starter does not turn over, nor does the starter solenoid click when the ignition key is in start position. I have checked the fuses and there are no blown fuses. I tried to locate the start relay but failed to locate it.
Please advise what should I do next and where would I find the start relay??
Old 01-06-2004, 09:59 PM
boschmann boschmann is offline
Re: VW Golf No Start
Automatic or manual? Is the alarm system working properly? Check to see if your getting power to the small red/black "trigger" wire on the starter when in start position.
Old 08-19-2004, 10:58 AM
emsinson emsinson is offline
Re: Re: VW Golf No Start
How can I bypass the alarm since most of the time it will mess up my day by not starting at all. Is there a better way of taking this alarm off? I used to take off the battery to have the car starts, but it will not do it lately. I do not have extra money to bring it to the mechanic to take off the alarm completely so not to interfere anymore with the starting.
I will appreciate if you can help me with this problem.
Thank you.
Old 08-19-2004, 03:58 PM
You can disable the alarm by unplugging the module under the dash. It has a 6 pin and 10 pin connector. To keep your starter working you will have to connect pin #5 & #6 of the 6 pin connector together.
Old 10-01-2004, 10:10 AM
plaeides plaeides is offline
Unhappy 97 golf won't start
I am having the same problem. I drive a '97 5 speed golf. One day I drove home from work without any problem, (except the coolant light was on), I parked, turned her off, added coolant and 3 hours later was unable to start her again. She cranks like she wants to start but can't. Timing belt is fine, ignition coil is all good. I can't rule out fuel pump, but she wouldn't even turn over when I sprayed some starter fuel into the intake valve. There's a good spark on the distributer cap and all the fuses work. Please, does anyone have any ideas? I'm too poor to buy a new car and can't afford a mechanic right now (I'm already replacing the transmission in my Nissan Quest).
I was having trouble with her stalling frequently recently...O2 sensor needs to be replace. You think these are related?
HELP!!!!
1999 Mk IV golf starting problems zuegma Golf 0 05-31-2005 02:31 PM
96 golf starting problem, starter sound but engine doesn't turn waghanna Golf 6 05-22-2005 08:33 AM
1996 Golf Starting Problems raylfitz Golf 2 11-20-2004 08:34 PM
golf starting/running badly nickso Golf 0 08-08-2004 11:07 AM
'77 golf starting to worry and confuse me BJIH_86 Golf 0 02-08-2004 05:54 AM
