Old 01-06-2004, 02:12 PM
PLOW BOY PLOW BOY is offline
2002 fuel pump problem
PLOW BOY []
Status: offline
12-30-2003, 11:56 AM 2002 Tahoe Fuel Pump Problem (Post #1)
I own an 2002 Tahoe with 62,000 miles. I did not purchase the extended warranty. About 2000 miles ago the car stopped cranking when the fuel tank had less than 1/4 tank. By adding a couple of gallons it would start. Then it starting dying on the interstate. If I pull over and waited a few minutes it would crank back up. My dealer tried to look perplexed and told me that GM had no official bulletin out yet, but they were experiencing plenty of problems. I have changed the fuel pump and bent the float mechanisim up 1 inch. Had no problems until this morning. It would not start until I added 2 gallons of gas. Also changed fuel filter several times, tank was clean when pump was changed.
Need help, wife's car, she is not happy!!!!!!
Report Post | IP: Logged
Old 01-10-2004, 08:46 AM
99ssconv 99ssconv is offline
buy the complete modular assembly and this will fix your problem, first of all you should have never bent the float arm, second the contacts on the fuel level sender are probably burnt.
Old 01-31-2004, 11:47 AM
jthomp2377 jthomp2377 is offline
What he said. I don't know if a modulater will help, hope so. But I mostly agree that you never bend the float.
1991 Regal Custom- Possible Fuel Pump Problem snickerkisses Regal 1 02-10-2010 10:08 PM
93 suburban fuel pump problem. robert1984 Suburban 2 12-15-2009 02:21 PM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
2002 Fuel Pump problem, Help please Liquidsteel2 Tahoe 1 10-11-2005 04:31 PM
