Old 12-22-2001, 06:27 PM
1badazzcivic 1badazzcivic is offline
Send a message via ICQ to 1badazzcivic
Swapping 94 Teg brake system to 92civic
Hey guys, I got a 92 civic dx and I have the whole suspension from a 94 Teg, will it fit and what will I need to do to make it work???? PLease help this guy from Halifax Nova Scotia........
Old 12-22-2001, 09:01 PM
Rice-Rocketeer Rice-Rocketeer is offline
The whole thing fits in like stock but why you would want to go thru all that trouble is beyond me, except maybe for bigger brakes or a 5 lug swap. Just get a Helms manual and start tearin it up. I believe you'll need the master brake cylinder and proportioning valve from a teg as well.
Old 12-22-2001, 10:27 PM
thanks for that help
Thanks for the help, the reason behind the swap is to have larger disks,better stopping and less fading. If you or any of your friend ever get a chance....check out our website "www.lowmotion.org" it's kinda like this one. But here in Halfax Nova Scotia.:flash: :smoka:
Old 12-22-2001, 10:37 PM
Re: thanks for that help
You can get the same thing by getting a big brake kit from a place like HP MotorSports. You can can use the stock caliper, 4 piston caliper, drilled and/or slotted rotors, or you can keep the same size as stock bembro rotors with pads, rear disc swap, ect. You don't need to swap out the whole suspention system just for that. Other than to say, "I swapped out the whole system."
Old 12-23-2001, 01:29 AM
piscorpio piscorpio is offline
Send a message via AIM to piscorpio
Im not too sure what the 92 dx's have for brakes, but I thought they had drums in the rear. If thats the case you can swap out the rear brakes in favor of the integra discs. Also, if your Civic is anything like mine, the front discs are already the same as the integra's, so there may not be a need to swap those. As far as the master cylinder and proportioning valve, I did not require either of those from the integra, but you should look into it more for your application. What trim was the integra, because if it was a Type R, then it could change things, otherwise the LS, GSR, etc. I believe are the same brakes.
Old 12-23-2001, 02:11 AM
madtownhonda's Avatar
madtownhonda madtownhonda is offline
Send a message via AIM to madtownhonda
the DX has 9.5" front rotors, so yes, the front rotors from the integra are 0.9" bigger with a better caliper....the rears are obviously better than the drum brakes...it's not a bad idea to go that route depending how much you spent on the setup
Old 12-23-2001, 08:02 AM
So do you know if I can just bolt the front disk and calipier from the 94Teg or do I need the whole spindle set-up? I'm gettin all the suspension and brake system for $300 CND so I have everything. Are the front A-arms the same ?
Old 12-23-2001, 07:38 PM
To do the front rotors and calipers you'll atleast need the teg steering knuckle. But if you're getting the whole thing for 300 CDN then don't worry about it. But I'm telling you a big brake setup will take less work and give a better result.
Old 12-23-2001, 09:15 PM
But would it be that cheap RR?
Old 12-23-2001, 09:29 PM
Not really but the end result will still look and perform a lot better. It's just if, you don't have alot of money, I'd get a rear disk swap, put some bembro and pads on those, then get some bigger rotors, adapter bracket and pads for the front. I've never heard of the whole suspension from a TEG being as cheap as 300CDN but for the price you usually find the whole teg systemin the US in a junyard, you could do something better in every way.
If you do have alot of money, get a Bear Claw system, and enjoy
Old 12-23-2001, 10:09 PM
Since I'm getting all the Teg shit for $300, I might as well put it all on. The front rotors are some kind of aftermarket slotted, and tha calipiers are aftermarket too, gotta be better that my wimppy stock DX brakes, Will the front A-arms fit of the 94 Teg ? cause thay have pollyUraethane bushings too. ?
Old 12-23-2001, 10:43 PM
Sounds like you got a really good deal then, Yeah, the entire thing fits like stock.
Old 12-24-2001, 07:40 AM
SaaaaaaaWeet ! Thanks. I shouldn't need the brake booster ? Thanks for the help, people on my board wouldn't be able to anwser shit.
Old 12-24-2001, 10:41 AM
Whtehnda93DXSdn Whtehnda93DXSdn is offline
Send a message via AIM to Whtehnda93DXSdn
Lightbulb
Here is a DIY link for doin the brake swap/conversion that you are doin.
DIY for Brake conversion/swap
the process should take you about 2 hours or so. I think a little more would be involved if you tried to just switch to a set of discs from the DX Drum setup.
I'm goin to swap mine here soon as well..you should notice a stopping diff for sure.
:frog: :frog:
another good honda site:
www.civicland.com
Old 12-24-2001, 11:38 AM
Id look into the other components (brake booster, proportioning valve, etc.), since your car is a DX it may not be as beefed up in those deptartments, just compare them to the integra's or Si's and be sure before you go ahead with the install (you could even find them from an EX like mine). Good luck with the project, and Im sure you will notice a difference, I did with only the rear discs being put in.
