Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 01-06-2004, 08:28 AM
gvhim6 gvhim6 is offline
2002 Keyless Entry Programming Instructions
Does anyone know the keyless entry programming instructions for a 2002 Yukon? Thanks for the help.
Old 01-11-2004, 10:25 AM
copout221 copout221 is offline
Re: 2002 Keyless Entry Programming Instructions
This worked on my 2003 Yukon.
Method 1 - No Tools Required, Program All Transmitters
Important
All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to 4 transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
Operate the transmitter functions in order to verify correct system operation.
Old 03-16-2004, 07:52 AM
svinzant svinzant is offline
Our 2002 Suburban Keyless Entry just quit working last week. I have the original keyless remote.
I tried the programming sequence listed above and the system locked then unlocked while in programming mode, but the keyless remote (original) does not work after completing the sequence. Any ideas? I'm assuming the system is both sending and receiving the signal between receiver and transmitter during the programming, but for some reason the thing still doesn't work.
Any help would be greatly appreciated - this is the wifes' vehicle and as you all know - if Momma ain't happy.....
SVinzant
Old 10-30-2006, 07:59 PM
n1iic n1iic is offline
Why don't you be considerate and give her your remote??? =]
Originally Posted by svinzant
...the keyless remote (original) does not work after completing the sequence.
Try programming all remotes (original ones and new ones) in every programming session.
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
2001 Blazer Keyless Entry Programming Instructions amcurry Blazer 11 03-02-2005 11:22 PM
Keyless Entry programming Instructions JavaKitti Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 7 06-19-2004 10:09 PM
help: 2001 grand am remote keyless entry programming instructions fleurie Grand AM 0 01-29-2004 10:01 PM
