Old 01-06-2004, 08:16 AM
mch7895 mch7895 is offline
Question 1999 Intrigue 3.8 Engine Hesitation
I have a 99 Intrique with a 3.8 liter engine with 90k miles. I have recently been noticing engine hesitation and my check engine light comes on. I have replaced the fuel filter and the PCV valve and the check engine light turned off. This seem to help for a week yet I am beginning to experience the same problem.
Any advise?
Old 03-04-2004, 10:59 AM
swingbobswing swingbobswing is offline
Re: 1999 Intrigue 3.8 Engine Hesitation
I don't have a solution for you, but a question. Where exactly is the PCV located on the 3.8. I assume it is on the rear of the engine toward the firewall, but cannot locate. I've changed it on other GM engines but can not locate.
Have you considered having you injectors cleaned? Either the do-it-yourself gumout method or professionally?
Good Luck! Bob.
Old 03-31-2004, 04:25 PM
Dr_Z Dr_Z is offline
First off, the "check engine light" can indicate and point you towards your solution and how to to fix your problem. Even if the light has only came on for a bit, and dosen't show up again, your cars PCM will have a Code Histroy that can be retrived with a suitable Scanner.
In most cases of vehicals with a "hesitation" problem (that be of, hard starting and hesitation of accelerator responce) can be a Carbon build up in the upper intake plenum, injectors, and/or plugged EGR Valve (Exhaust Gas Recirculating Valve). I would suggest a good cleaning with a "motor vac" machine after you have fixed any problems found from the PCM's history Codes.
Dr_Z
3.8 head changes. help? thunderbirdcoupe89 Thunderbird 2 12-10-2009 11:43 AM
Replacing my '98 regal engine. Is this a good rate and engine price? bchalker Regal 1 08-25-2009 07:05 PM
1999 Intrigue 3.8 Crankshaft Part # Relly Intrigue 2 03-01-2009 08:33 PM
1999 Intrigue 3.5 with a engine from a 2000 1999OldsIntrigueGL Intrigue 17 02-01-2009 02:13 PM
1999 Intrigue 3.5 engine rough idle larryg535 Intrigue 1 05-09-2007 01:55 PM
