Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-06-2004, 02:39 AM
craigkw80 craigkw80 is offline
Unhappy passlock system on 2001 malibu
Can anybody give info on how to start my car with this passlock crap. don't know what to do
Old 01-07-2004, 11:46 AM
JustJosh JustJosh is offline
Talking THis worked to fix my passlock!!!!!!!
I was having problems with the passlock as many others have been having as well. I took the ignition cylinder out and took it apart. To remove the ignition cylinder you have to press in on a pin that is on the back of the ignition cylinder with the key in and turn it and pull and it will pull out. To take the cylinder apart you all you have to do is line up the end with the groove on the inside of the cylinder, the part the key is in, with the channel on the outside of the cylinder and depress the part with a paperclip and slide it apart. There are a few small pieces and springs so be careful!! Now you just have to clean the contacts and reassemble it. That little cleaning saved my at least $300. I hope that this helps some with their problem!!!!!!!!!!!!
You may even try just cleaning it with carb cleaner and turning it without taking it apart and then blowing it out with air. I had not thought about that but looking back I think it shouldwork as well. TO lubricate it use graphite powder and your hopefully up and running
passlock on 2000 malibu redneckwoman Malibu 19 12-28-2013 11:30 AM
Passlock Issue - 2001 Chevy Malibu RandoTheKing Malibu 3 08-18-2010 01:43 PM
2003 Malibu I suspect passlock system mprocyshyn Malibu 2 04-11-2010 08:50 AM
2001 Malibu Antitheft System mrbayou66 Malibu 11 10-21-2004 05:23 PM
Passlock System on a 98 Malibu Mesa98 Engineering/ Technical 0 08-23-2002 11:35 AM
