Old 01-05-2004, 09:18 PM
TomGPGT2000 TomGPGT2000 is offline
Question thrasher or fender wall for gt
what should i get installed in my car. the thrasher cold air induction kit or the fenderwall intake with the k and n from pfyc.com..... i have a grand prix gt 2000,,, with 54000 miles on it. this would be my 1st mod on my car... i herd that the thrasher is more for the gtp's..... what system would give me more power.... i allready sent in the check to pfyc so its gona be 1 of those 2 intakes.... thanks a lot....
Old 01-05-2004, 10:22 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
I doubt you'll see any difference between the 2.
The fenderwell is going to give you the coldest air possible.
You can make one cheaper then the one on PFYC
PM qball - he might have a few intakes left
Here is another nice FWI http://www.cheetahonline.com/k3022.html
Old 01-06-2004, 02:57 PM
JJUBECK JJUBECK is offline
Re: thrasher or fender wall for gt
The colder the air the better right?
So what are the down falls of the fenderwell intake? And the benefits of CAI?
Old 01-06-2004, 05:11 PM
GTPCatz GTPCatz is offline
Banned
www.zzperformance.com
Just did a study on intakes....might be worth the read....there are pros and cons of a fenderwell
most the cons are just now being discovered...
Old 01-06-2004, 10:09 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Following GTPCatz input. Here is the URL:
http://www.zzperformance.com/zzp/inf...ns_airflow.htm
IT is interesting that removing the screen would increase CFM's. I tought that because the screen would take care of air turbulence having it off would affect flow but was on the contrary. And based on the information presented the Chetahh instead of helping you could really restrict the flow into the TB. Interesting . . .
Old 01-07-2004, 11:08 AM
Yeah very intresting..........so the CAI is the way to go..............wow and I wanted a FWI to, thats worse then the ghetto intake I have now. Thanks for that link.
Old 01-10-2004, 07:41 PM
Lastweak Lastweak is offline
ok i've seen the results from that artical on zzp and ive seen all the different air boxes and what not, and when i seen what the hell these guys were charging for some PVC and a boot i thought i'd make my own i went to a local performance shop picked up a reactive air filter for 35 bucks went to Home Depot bought 7 dollars of 4 inch Pvc and 2 $4.50 4 inch rubber boots then went home to build it.. i relocated my PCM just behind the coolent bottle overflow, vertically, then drilled out a 1/2 inch whole in 1 boot then sliped it onto the Throttlebody tightend it down measured out how much PVC i'd need about a foot and a half sliped the other boot onto the other end slid the filter inside tightend the to belt like things on them(sorry don't know what there called) placed the filter into the triangle like hole were that thin plastic piece with the hole was then attached the tube into the boot on the TB tightend them up put the senser into the 1/2 hole and i was set took about 45 mins cost 16 bucks plus drive to home depot results a much improved breathing Devise thats loud as fuck.
PS: i don't advise removing the screen in my car (98 GT) it set the SES light off and had no noticable affect
Old 01-10-2004, 10:44 PM
kilroypr's Avatar
If you read the article the longer the PVC the more restrictive the airflow. You got your principle correct. What I would you If I were you is instead of having the PVC be 3' long and the filter on the triangle shaped intake fender hole to have just 4" of PVC and have the filter there. The shorter the PVC the more CFM's you will get.
And what was the code your car got when you removed the screen?
WTB: Dark grey metallic factory fender flares for my 2003 silverado bans25 C/K 0 02-08-2004 10:07 PM
anyone know where to get black fender flares for rodeo isuzu? honda1998civic Rodeo | Passport | MU 1 01-16-2004 02:50 PM
Looking for OEM GM fender flares for a 99-04 Pewter bans25 C/K 0 11-24-2003 06:18 PM
Custom made fender eliminator for any bike save some $$$ creese Street Bikes 1 07-01-2003 11:15 AM
Custom made fender eliminator for any bike save some $$$ creese Dirt Bikes 0 07-01-2003 06:11 AM
