Old 01-05-2004, 05:22 PM
awicks awicks is offline
99 Taurus wipers come on
Another of my many Ford Taurus problems. The wipers like to come on by themselves. Can live with the wipers coming on but the noise that they make on the dry winshield is unbearable.
Old 05-13-2004, 11:28 AM
nedward nedward is offline
Re: 99 Taurus wipers come on
Refer to post "Spooky electrical problems (99 Taurus)" This post leads you to the Tech bulletin given by ford on that wiper issue. It appears they reccomend replacing the Multi-function switch. $90 from the dealer. I havent tried it but I dont think it will be that hard.
Old 06-26-2004, 09:12 PM
LarryKL LarryKL is offline
Had the same problem. Multifunction switch was the fix. Easy to install, hardest part for me was removing the ignition lock cylinder - drove me nuts. I just used a small nail to gently push up the retaining pin to remove the lock cylinder. Chilton's manual helpful.
Old 06-27-2004, 12:36 AM
mikestone1776 mikestone1776 is offline
Thumbs up Re: Re: 99 Taurus wipers come on
You must be right. I had the same problem, took the car to a locksmith who repairs steering columns. He replaced the switch with one of his "many" used ones! Same problem again. I want to locate the Ford Tech bulletin so I can convince this guy to let me buy a new switch, and let him install it. (he has my money already) Can you quote the Tech bulletin please, or point me to it.
Thanks
Mike Stone
Old 06-27-2004, 10:31 AM
TSB Article No. 00-9-6, titled "Windshield Wipers-Front Wipers Operate While Switch is in "OFF" Position". It recommends multifunction switch replacement - Part Number XF1Z-13K359-AAC
Old 06-28-2004, 11:27 AM
Mike, I hope this link works, here it is.: http://www.thedieselstop.com/faq/949...les/000906.pdf
