difficulty level?
how hard would it be to install an electronic air fuel ratio guage, mechanical oil temp and mechanical fuel pressure guage?
just ordered these and hope i don't kill myself trying to install
![]() » Supercharged 2006 Honda Civic Si Coupe » Info | Teaser Video | Dyno Video | Dyno Graph |
the air/fuel is easier than the fuel pressure and the oil. the reason being is that the air/fuel is electrical and the other 2 are mechanical. i heard the mecanical guages are harder to install because they have liquid running through the lines or something (unlike the electrical...they only install with just wire) other than that i could not help you. check the FAQ they might have install directions.
good luck l8r |
2slow is right...
for the A/F guage that will just be a mater of hooking it to an ignition wire and ground it then run a lead to your ECU or under the hood for the O2 hook up. As for the other 2 you will probably need to tap into a oil supply/pan to get that reading. as for the Fuel guage if I'm right that will need to be mounted outside the car as you don;t want to run a fuel line into your ride. So that will go under the hood inline w/ your fuel. I know about the fuel guage as I had one that I wanted to go in my ride but I had to mount it out because of the factor I just stated.. Hope this might help a little more.. :frog:
another good honda site: www.civicland.com
