Old 01-05-2004, 12:57 PM
coyote03 coyote03 is offline
EGR not working
I have a '94 with the 3.0L. I have pulled a "332" code from the computer "insufficiant EGR flow". There is zero vacuum at the EGR valve up to 2800 RPM (I didn't go any higher). I have replaced the EVP and EVR with any effect. Any help would be much appreciated.
Old 01-11-2004, 12:38 PM
werty101 werty101 is offline
egr
remove your throttle body an see if there is an egr passage under the gasket. I had same problem with my 3.0 dohc and all it needed was the egr passage cleaned out, after spending $75 for a sensor ford has had a problem with clogged egr passages for years
97 Breaks not working crackedvenom Taurus | Taurus Wagon 1 05-12-2010 08:17 PM
Replaced EGR now Temp guage not working!! misseth1 Express | G Van 3 11-24-2009 09:15 AM
94 Plymouth Voyager WON'T IDLE AHHH! Not EGR Not Idle Air Control HEELLLP! dadscarisaheadache Caravan | Voyager 3 03-28-2005 02:56 PM
4X4 control panel lights not working 4 wheel drive not working french69ssrs S-10 1 12-28-2004 04:25 PM
