remote starter
I installed a remote starter in a 96 Dodge Caravan and everything was easy except for the power door locks. I can't find the wires to splice into. Directions say the wire color is white with dark green stripe located at the body control module. Anybody have any ideas to where to look?
Re: remote starter
The single wire you are looking for is in one of the black connectors going up into the bottom of the BCM I can't remember which one. I assume that you know about the resistor values to use on this wire? If not post again and I'll dig them up for ya! Oh ya it also makes a difference in the resistance values if you have factory anti-theft.
Re: remote starter
1996 Dodge Caravan Security Information
Constant 12V+ Red or Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue Ignition Switch Harness Ignition 2 Dark Green/Red Ignition Switch Harness Accessory Black/White Ignition Switch Harness Tach Gray/Red Or Blue/Tan PCM Coil 2.4 Liter Engine Neutral Safety Wire Black/White Power Control Module Brake Switch White/Tan Brake Switch Trunk Pin Tan/Black 40 Pin Connector at Fuse Panel Parking Lights Light Green/White (-) Head Light Switch Harness left of Column Head Lamp Green/Orange Light Switch Hood Pin Brown Driver's Side under Hood Factory Disarm White/Dark Green (665 Ohm) left Connector bottom of Fuse Panel Door Trigger Brown/White (-) Lower right Gray Connector at Fuse Panel Door Lock White/Dark Green (-) BCM at Fuse Panel 1500 Ohm Resistor Door Unlock White/Dark Green (-) White Connector B58 Connector 250 Ohm Resistor Driver's Lock Brown (+) Junction Block Driver's Unlock Purple/Yellow (+) Junction Block Horn Wire Black/Red Steering Column Windows Up LF=Light Green, RF=Brown, LR=Blue, RR=Gray Windows Down LF=White, RF=Purple, LR=Red, RR=Dark Green
MegaMax ![]()
Dre's Corner www.Maxima.Org www.superstallions.com www.f150online.com |
Re: remote starter
I had also installed a remote car starter. Everything works fine, except for the headlight indicator wires. While I was trying to installed the headlight wire, all lights on the dash and tail light started blinking rappidly like crazy. I decided to not monkey with it and left it out. Any suggestions on what I might be doing wrong?
Re: Re: remote starter
do you have the lay out to install a remote start on a 91 gc ??
Dayalalito |
