Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 01-04-2004, 11:22 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Lowering options
wanting to buy springs for 91 civic but was wondering how low i should go. whats the lowest i could go (to lose wheel well gap) without causing scraping problems or mess up performace on 17's ? would 1.7 be a big difference?
Old 01-05-2004, 12:18 AM
BullShifter's Avatar
Re: Lowering options
The lowest I recommend for daily driving is 2". When you drop 2" or more suspension selection becomes a major factor. 17's make the suspension, brakes, & engine all work harder - reducing performance. Also you will need a camber kit for proper alignment w/ 2" or more drop. Camber really isn't an issue when lowering 0-1.75"
Old 01-05-2004, 03:16 PM
copasetic808 copasetic808 is offline
lowering a 07 civic ex with 7.5 in width rims?
i got a question for the suspension experiments/...would be much appreicated..
i have a 97 civic ex...i have 17 in rims but they are 7.5 width...and the most you are supposed to go is 7 in.....i didnt know that when i bought them...i went to the racing shop by my house and they said they could give me agx shocks/struts with tenzo springs....and it would drop about 1.75 inches...and the struts would be adjustable for softness or hardness...however they guy said if i camber it will rub....
so does this mean i either have to go around with the ghetto fab looking wheels where they vear out....or i half to camber...i know cambering is better..but if i have any more than two people in my car it rubs as it is at stock specs....what should i do....have sucky steering and tire wear but no rubbing or get camber?????
im lost
Old 01-06-2004, 03:26 AM
Re: Re: Lowering options
do you think that 16's is better???????
alot of my civic buddies have been getting 16's merely for the fact they have bent too many rims on curbs and what not....
what do you think for performance is the best size for a civic?
Old 01-06-2004, 02:29 PM
Re: Re: Re: Lowering options
Originally Posted by copasetic808
do you think that 16's is better???????alot of my civic buddies have been getting 16's merely for the fact they have bent too many rims on curbs and what not....
16" is the largest I'd put on a civic, 14-16" preferred. Besides bending wheels, the ride quality is crap on 17's or larger. The lighter the better.
Shorter overall diameter(tire) - acceleration
Taller overall diamete(tire) - top speed
Lowered BMW problems... :-( Ashleyyy 3 Series 0 04-18-2010 12:30 AM
Lower radiator hose cool/Water pump squeal ktl4974 Problem Diagnosis 7 05-04-2009 08:44 PM
Lowering Options david-b Engine, Transmission and Drivetrain 14 02-06-2007 10:44 PM
98 civic lowering options 98CivicDXMT21 '96-'00 Civic 2 01-23-2007 05:42 PM
best option for lowering a 92 c1500 doughboy_customz C/K 5 11-29-2004 06:34 PM
